Old 08-06-2008, 12:48 PM   #1
Ford Assassin
Ford Assassin's Avatar
Question Are 12 bolt car and 12 bolt truck backing plates the same?
I ask because I want to piece together a rear disc brake setup for my '69 C10. There are brackets out there that state they will bolt onto a 10 or 12 rear end, but I wonder if they mean trucks too.
These are an example:
http://cgi.ebay.com/ebaymotors/Rear-....c0.m245.l1318
I think I am going to swap to 5 lug axles and wanted to do a rear disc brake swap in the process. Thanks guys!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 08-06-2008, 03:46 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Are 12 bolt car and 12 bolt truck backing plates the same?
movin off the burb page, to the truck board
Old 08-06-2008, 04:27 PM   #3
Ford Assassin
Oops, my mistake. I thought I posted in it in the truck forum.
Cable
Old 08-06-2008, 05:47 PM   #4
crazy longhorn
Fabricate till you "puke"
No sir, those brackets are not the same as truck. IIRC, the Impala has the same housing ends as the truck rear, but the mid sized cars have a different end & bearing(bolt pattern is different for the backing plate). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-06-2008, 10:21 PM   #5
Mike C
Mike C's Avatar
Correct. Big Car and Truck had same flange pattern for the backing plate. Big Car and Truck use larger wheel bearings than the small car (Camaro/Chevelle) The JL-8 Camaro uses the small bearings but has the large pattern which allows the use of the Corvette caliper mounts, but this is a more complicated disc swap than most. Best bet is to buy an aftermarket kit that comes with the correctly sized aftermarket parts.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-06-2008, 10:22 PM   #6
Ford Assassin
Thanks guys!!
Cable
Old 08-20-2008, 01:28 PM   #7
Ford Assassin
Anyone have a source for just the caliper brackets?
Thanks!!
Cable
