Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 08-06-2008, 02:18 PM   #1
Jabby
Newbie with 72 Blazer 2wd question
A customer of mine has requested a serious quote to transfere a 72 Blazer (4X4) body onto a 79 Blazer 2wd chassis thats already blasted and front end redone (aftermarket upper and lower control arms ect.). Am wondering how extensive this job is? Frame shortening? Body mounts? We run a two man body, restoration, fabrication shop so we have most all the tool and equip. needed. Thank you for any responses ahead of time.
Jabby is offline   Reply With Quote
Old 08-06-2008, 03:51 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Newbie with 72 Blazer 2wd question
Welcome to the board from Texas
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 08-06-2008, 04:33 PM   #3
Jabby
Thank you jsbgump.
Old 08-06-2008, 06:57 PM   #4
DREAMS OF A 67
Step Brother
DREAMS OF A 67's Avatar
Smile Re: Newbie with 72 Blazer 2wd question
FROM KNOXVILLE TN!!!
Joe
DREAMS OF A 67 is offline   Reply With Quote
Old 08-07-2008, 01:20 AM   #5
shaneschevys
Its always something!
shaneschevys's Avatar
Welcome from FT Worth TX.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 08-07-2008, 06:12 AM   #6
Cyclone44
Step Brother
Cyclone44's Avatar
from Knoxville Tn...
Cyclone44 is offline   Reply With Quote
Old 08-07-2008, 08:14 AM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
to the board from Mid-MO!!!
You might post your questions in the message board.
Good luck with the swap!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-07-2008, 03:04 PM   #8
hotrodhomi
hotrodhomi's Avatar
If they were the same year they would bolt right up but I;m not sure about bolting a 1st gen blazer onto a 2nd gen frame. It might be easier take the front crossmember from the 2wd and bolt it to the 4x4 frame, it will fit with a few extra holes drilled. Then you could four link the rear end.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 08-07-2008, 04:35 PM   #9
raggedjim
raggedjim's Avatar
I'm reasonably sure the wheelbase is different on those and the mounting points will be also. Not insurmountable but also not something I would do. I would use the original 4x4 frame, swap in the new front end stuff from the 79 and weld in the mounts for the leaf rear axle from the 79 (heck, it may fit the existing 4x4 mounts...)
Rg
raggedjim is offline   Reply With Quote
Old 08-07-2008, 09:05 PM   #10
rigon4
rigon4's Avatar
im not positive but the 1972 has a wheel base of 105 in. and the 1979 is 106.5 in. but what i would is take the 79 front end and put it in the 4x4 frame and find a 71-72 rear end and trailing arm set up to bolt in.
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 08-09-2008, 10:16 AM   #11
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welcome to the board from southern oregon.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-09-2008, 10:50 AM   #12
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Welcome aboard from Northern California!
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 08-11-2008, 04:46 PM   #13
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
from South Texas! I'm witht he other guys, swap the front crossmember and steering in, then change up the back. Much easier than a body swap IMO.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 08-11-2008, 06:04 PM   #14
Jabby
Okay thanks, I was under the impression that taking the 4X4 stuff off and puting the 2wd stuff in (t-case, crossmember, front suspension) would be a lot larger job than swapping the body mounts, I have never done a front susp. swap and thought it looked like alot of work.
Old 08-12-2008, 10:03 AM   #15
raggedjim
raggedjim's Avatar
Tons of people have done the front suspension swap, there's probably a thread on here somewhere...
I think Gringoloco could help you out...
Good luck, Rg
Old 08-13-2008, 07:21 AM   #16
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
from CT!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 08-13-2008, 08:41 PM   #17
chevguy7
chevguy7's Avatar
Welcome from Washington!
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
Old 08-13-2008, 10:34 PM   #18
scotts62
One day...
scotts62's Avatar
Welcome from OKC
Scott
93 crew cab build
Project 62
Old 08-15-2008, 03:10 PM   #19
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Hi, and welcome, from Indiana!
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 08-17-2008, 11:55 AM   #20
CAL 58 GMC
CAL 58 GMC's Avatar
Welcome from Central California!
CAL 58 GMC is offline   Reply With Quote
Old 08-25-2008, 03:24 AM   #21
L0WRIDE
L0WRIDE's Avatar
Welcome to the boards
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 08-25-2008, 11:04 AM   #22
Jabby
Thanks all for all of the welcomes, it is greatly appreciated.
