Mean Buzzin' Half Dozen
Loose Wheel Hub, Not the Bearings
Okay, well my front driver side wheel is loose, the hub and all. Me and my dad figured it was the wheel bearings, so we went out and bought the bearing and put it in, that's a no go. It didn't do anything for the wiggle in the wheel. When I drove it I hear like a grinding kind of noise due to the wheel shaking I suppose. Is there any way I could fix this loose hub, and what do I have to do?
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale) 1967 C10 SWB Dylan |
Son of a gun
Re: Loose Wheel Hub, Not the Bearings
did you replace both the inner and outer? did you snug the nut until you did not have any play?
Bill BEATERS ARE NEATER |
Yeah, I replaced both bearings, and I can't picture what nut you're talking about, I'll go pull the wheel off and give it a look right now.
![]() Join Date: Apr 2008
There should be a big washer and a nut outside of the outer bearing.It should also have a cotter pin in it to keep it from backing off.
the nut in the center that holds the whole hub assembly on is what we are refereing to
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333 |
Thanks guys, the nut was it, I guess I just didn't tighten it enough when I was putting it all back together. All the slop is gone now!
Thanks again, Dylan
I swear I just read somewhere to tighten it to 12ftlbs and no more - rotate the wheel to seat the bearings, back the nut off and then only hand tighten it and then put the cotter pin in. I think it was in a haynes manual if I'm not mistaken.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
Never Ending Projects
Don't overtighten the wheel bearing nut or you will toast your new bearing very quickly. If you don't know what the specs are or are not familar with how it should "feel", get a shop manual and do it right.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
So now I have a new problem... It has nothing to do with the wheels, so off that topic. I started it up today and I was sitting there revving it some and warming the engine up. Well I went and revved it a little and the engine just died. I figured it may be the fuel pump, checked it, it's good. Then checked the ignition coil, well it's not putting off any spark so we were like hey, get a new coil. We go to advance and get a new coil, put it on, still no spark coming out of the coil to the distributor. We checked and the coil is getting power, it's just not putting any out. For the life of us we can't figure out why not. Anyone have any advice on this?
Gone to greener pastures
![]() Join Date: May 2007
Did you check the points?
If they're not opening (or closing) you won't get any spark.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
member #16
![]() Join Date: Dec 1999
Did you check the points and condensor? If the points are closed or burned the condensor is shot you will not have any fire from the coil.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Well the points are in the distributor, and there's no power getting to the distributor, so why is the power not coming out of the coil?
#13 |
![]() Join Date: Sep 2005
if you points are burned out it will not have power to the coil, the distributor feeds the coil
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 08-06-2008 at 10:38 PM. |
#14 |
I thought it was the starter that fed the coil and the coil fed the distributor, which distributed the sparks to the plugs. Why would it go backwards and feed the coil? I'm just completely lost. I'll most certainly have to look at the points tomorrow though.
#15 |
the black wire off your points goes to your coil on the neg side of the coil if your points are burned out they will not ground out and the coil will not fire
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 08-07-2008 at 07:16 AM. |
#16 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#17 | |
Active Member
![]() Join Date: Jul 2007
So when the points are closed and the ignition switch is turned on, a magnetic field is built up around the coil. When the points are opened by the distributor cam, electrons can no longer flow, so the magnetic field collapses toward the center of the coil at the speed of light. When it collapses, it moves through the secondary coil. Since the secondary coil has so many turns of wire, and the speed of the magnetic field is so high, a great deal of voltage is induced into it. |
#18 |
Oh okay, I think I see what you're talking about on the ground where the negative wire leads into the distributor. I'm going to check that either later tonight or if I can't get to it tonight it's going to have to be on Tuesday when I get back from vacation. Thanks for the help guys, I'll keep y'all updated.
Edit: just read through the stuff on that link, it makes a whole lot more sense now. "The points are not anything mysterious. they are simply a mechanical switch that turns on and off the ignition coil. The are opened by the distributor cam, and closed by the point spring. When they are closed, the electricity flows from the battery to the ignition switch on the steering column, to the positive side of the primary coil, and across the points to ground. The only way the electricity can get to ground is across the points, so when the points open, electrons can no longer flow and the magnetic field around the coil collapses." Thanks a million for the link.
MY TRUCK (Now for sale) 1967 C10 SWB Dylan Last edited by *Dylan; 08-07-2008 at 03:26 PM. |
#19 |
It was the points guys. Thanks for the help and my truck lives once again
#20 |
Active Member
It'n it great!
