Old 08-06-2008, 05:47 PM   #1
lookingtobuy
lookingtobuy's Avatar
REBUILDING MOTOR And TRANSMISSION!
Hi All,
I finally broke down and decided it was time to rebuild the motor and trans.
They are the originals with the ODO reading (1)20,000. Matching numbers to the protecto plate. I am going with a B&M shift kit and H.D. torque converter.
I want to have th motor balanced and add an R.V. cam. up the compression and go to electronic distributor. I also want to go with a new water pump and fuel pump.
Sorry about being long winded.... My question to the professionals..can you give me some recommendations as to manufacturer and model of some of the motor parts I should go with. Its just a weekend cruiser, no rock climbing or bog running, or 1/4 miles.... : )
Thanks... and since y'all like pictures.. heres the teardown
lookingtobuy is offline   Reply With Quote
Old 08-06-2008, 05:53 PM   #2
lookingtobuy
Re: REBUILDING MOTOR And TRANSMISSION!
i was agressive with the camera
Old 08-06-2008, 06:01 PM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
Clevite bearings
Keith black pistons, Hypereutectic (sp?)
Edelbrock intake
Vortec heads (that's just me though FYI, the new heads probably wont be too much more than getting your old ones rebuilt
I'd probably keep using the q-jet but alot of people go with the edelbrock 600 or holley truck avenger 670
New harmonicbalancer as well
Comp cams 256 cam
You'll get 300+hp with this combo and it will be a nice cruiser also.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 08-06-2008, 08:07 PM   #4
jaros44sr
jaros44sr's Avatar
Nice pics., thanks for sharing. Always cool to see them brought back. Can't imagine how many of us has that same green color. I'd just freshen everything up and put it back together (worked for the first 120,000 miles)
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-06-2008, 09:11 PM   #5
BLUE THUNDER
BLUE THUNDER's Avatar
I bought a GMPP 260hp 350 and am just about ready to fire it up. I've seen this motor run and it's great. I couldn't pass up the $1,500 price tag and certainly couldn't pass on the reliability factor. I too pondered the buy/rebuild question, but when it was all said and done, this was the way to go. Mario
BLUE THUNDER is offline   Reply With Quote
Old 08-06-2008, 11:49 PM   #6
truckster
truckster's Avatar
I like the suggestion for the Vortec heads, but you'll have to change your valve covers as well as the intake. I am a fan of the Quadrajet, so I'd rebuild it if it's in decent shape. I also like the GM factory HEI. They work great and you can usually pick one up pretty cheap.
truckster is offline   Reply With Quote
Old 08-07-2008, 10:20 AM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
From what I've heard, those Vortecs are a good way to go as mentioned above. There are some pretty helpful members over in the engine & drivetrain forum that can also give you some great advice on your question.
Be sure to document and keep us posted as you proceed! As you know, we all like lots of pics, so that is never a problem!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-07-2008, 10:51 AM   #8
lookingtobuy
Hi and thanks so far.... I think that I'm going to stick with the stock heads and intake, maybe beef up and balance the internals. Factory HEI sounds good Ill look in that. Ill keep you posted!!
Old 08-12-2008, 02:18 PM   #9
airdale94
airdale94's Avatar
You'd have to cank the longhorns also if you went with the vortecs, from what I hear.
airdale94 is offline   Reply With Quote
