![]() Join Date: Aug 2003
Eaton ?
How can you tell if this is a posi or not. Is there an easy way to tell.
Re: Eaton ?
I think the no-spin was the only option, and not a "posi" which is a clutch type. Based on the side gear I see, I'd say it is an open diff. The No-spin (or Detroit Locker) has toothed engagement gears and not the regular side and spider.
67-72 Addict!
Re: Eaton ?
This is an eaton posi
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Re: Eaton ?
OK,I'm looking for a pic of an Eaton NO-SPIN in a 3/4 or 1 ton,not 1/2 ton. Sorry for the confusion.
I have a radical idea!
Re: Eaton ?
It may be an Eaton posi, but that's a 12 bolt rear. Uncle needs pics of a posi/no spin in an Eaton HO72 or HO52.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 08-06-2008 at 10:54 PM. |
#6 | |
Re: Eaton ?
![]() No-spin diff: ![]() EDIT: for s&g factor, here is a NOS No-Spin...snagged this pic off eBay a couple years back: ![]() Finally, an original in the cab No-Spin sticker (thanks Yukon jack for the pic): ![]()
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 08-07-2008 at 12:13 AM. |
Re: Eaton ?
Thanks.
