Old 08-06-2008, 09:14 PM   #1
jfromtn
Guest
Posts: n/a
windshield removal
whats the best way to remove the seal and windshield without breaking the glass. thanks
Old 08-06-2008, 09:51 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: windshield removal
1st From West TN
2nd If you don't car about the seal, utility knife
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-06-2008, 11:46 PM   #3
truckster
truckster's Avatar
I second that. Even with a new rubber gasket, it's difficult to remove one of these windshields without breaking it. If your gasket is old and hard, forget it. Cutting the rubber is the only way.
truckster is offline   Reply With Quote
Old 08-07-2008, 08:07 AM   #4
Bentblazer
Bentblazer's Avatar
Asked the same thing a couple of months ago, received good advise from all. Tryed to post the link, to my question, couldn't do it sorry. If you can go back I have a thread titled windshield removal also. My advise use the razor knife method, get new seal. I tryed to save my seal, not worth it.
Bentblazer is offline   Reply With Quote
Old 08-07-2008, 08:13 AM   #5
Number98
Prestige Worldwide
Number98's Avatar
Yeah, cut the seal with a utility knife around the inside of the window edge. Usually it's brittle and will begin to split once you start the cut and you can pull it along the window as it rips. Then you can carefully lift the window out forward.
Worked well for me using this method because you usually need a new seal anyway.
Number98 is offline   Reply With Quote
Old 08-07-2008, 08:16 AM   #6
vtblazer
vtblazer's Avatar
Here's the link:
http://67-72chevytrucks.com/vboard/s...d.php?t=291200
Cut the existing gasket and replace it, you'll be glad ya did.
vtblazer is offline   Reply With Quote
Old 08-07-2008, 12:17 PM   #7
lyrikz
PITbut
lyrikz's Avatar
Look, this cant be simplier. CUT the seal, and then the window just FALLS out. ahahah.
lyrikz is offline   Reply With Quote
Old 08-09-2008, 10:58 PM   #8
jfromtn
Guest
Posts: n/a
thanks for all the advise . will do
