08-07-2008, 12:43 AM | #1 |
Not a bad nut after all..
TH350 in my Project Truck Fubar (see pics)?
I recently bought a 1972 Chevy 1/2-ton 4x4 with a TH350. The previous owner stopped driving it in 2002 because "it wouldn't move anymore". Even though the column shifter and linkage was hooked up and looked okay, I couldn't feel any of the detents in the transmission. I dropped the pan tonight, and found the S-hook hanging in the pictures loose in the pan. Also the detent roller/lever does not contact the cogs because the piece with the cogs is flopped out of place (pardon my highly technical terms). What all is wrong here?
I also included a picture of the truck the day I brought it home (rough body but fairly unmolested overall).
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer Last edited by badpeanut; 08-07-2008 at 12:47 AM. |
08-07-2008, 02:59 AM | #2 |
Re: TH350 in my Project Truck Fubar (see pics)?
Well we need pic with the filter removed to see whats going on with the manual shift valve, which is what that s shaped linkage is post to be hooked up to. The whole shift assembly is way out of place as in shifted to far, the rooster head cog thing is post to have the spring rod thing with the roller in the cogs. heres a pic
67 3/4 Lwb Step side X San Diego County truck 70 3/4 berb was 402 Th400 Dana 60 now just the dana 70 3/4 lwb Fleet Choptop bagged th350 no eng yet 79 rx7 Wide body 350 TPI t5 flat black(The interceptor) 64 comet mounted on a 93 Thunderbird chassis. |
08-07-2008, 01:19 PM | #3 |
Thanks for the picture Omnivec!
I'll take off the filter and get some more pictures of mine. Is the hole in the aluminum case above the shift assembly in my first and second pictures supposed to be there (the tan "object" can be seen though the hole)?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
08-08-2008, 05:46 PM | #4 |
Yeah that's normal its probably for inspection of one of bands. I don't know the name
08-08-2008, 06:07 PM | #5 |
Looks like someone installed a shift kit maybe and didn't get the S hook installed correctly? Pull the filter, and it'll be pretty clear what might be going on. On another note, the fluid looks really red for a used trans, maybe it is fubar'd and they tried to "fix it"? Just hook up the S clip, and the shift detents and give it a try?!
08-08-2008, 07:48 PM | #6 |
The PO said the transmission was recently "rebuilt" (recently meaning shortly before he stopped driving it in 2002). I don't know what "rebuilt" means for this truck since the other work he did wasn't great.
Here are some pictures with the filter off (I hung the S-hook on the manual shift valve for these pictures). Before I can test this transmission I need to get the truck running.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer Last edited by badpeanut; 08-08-2008 at 08:37 PM. Reason: clarification |
08-08-2008, 09:59 PM | #7 |
It looks as if the rooster comb (what the detent spring rides against) is bent. Try this loosen the bolt that holds the spring against the valve body, and then verify that the rooster comb is tight against the rod that goes to the external linkage, (it should be a 9/16 nut). Insert the s hook and the tranny should be fine. If the nut is tight, loosen it pop out the clip between the case and the comb and get a new comb.
08-10-2008, 03:30 AM | #8 |
all you need to do do is hook the s link up correctly. it wont drive because the manual valve cant direct fluid to put it in gear cause the s link isnt hooked to it. the fluid looks perfect cause it was rebuilt. you got lucky cause po was to lazy to find out why. the rooster comb is supposed to be curved for tension(should have a lot and its bolt torqued to spec. the s link can only go on one way so there is no way it can just slip off(you will understand when you put it on correctly. hope this helps.
08-10-2008, 10:03 AM | #9 | |
08-10-2008, 10:08 AM | #10 |
It should be as simple as putting the detent spring back on (that is why you can't feel anything in the shifter) and reattaching the the S-link.
In the following pic: The S-link goes to the hole where the arrow #1 is pointing. Loosen the bolt, arrow #2, and lift the spring/roller up and over to the teeth on the selector shaft. (arrow#3) Hold it, with the roller wheel centered, and tighten the bolt back down. Of course there could be more problems, but this is a good start. Last edited by LONGHAIR; 08-10-2008 at 10:09 AM. |
08-10-2008, 11:19 AM | #11 |
Old School, New Style
It should look like this when you are done.
Same thing happened to me and it just happened to be that the comb was pushed off the roller spring because the comb nut had come loose. Really easy fix.
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
08-10-2008, 11:30 AM | #12 |
Thanks everybody for all the help! I should be able to figure this out.
I'm going to get a new filter and fluid this afternoon. I'll post an update with the results.
08-10-2008, 05:08 PM | #13 |
thanks Dhal for the pics, i am clueless how to post em. remember that 100 in. pounds is different from 100 ft. pounds. your wrench should do one or both measurments.
08-25-2008, 12:40 AM | #14 |
Thanks everybody, the comb nut was loose and I was able to put everything back together with the pictures and descriptions. I replaced the filter for good measure. I'm working on getting the rear driveshaft in and the truck running now so I can test it.
08-25-2008, 05:40 PM | #15 |
Exactly what happened to me. Doesn't it make you feel good that it was so simple?
