Old 08-07-2008, 01:29 AM   #1
tdave00
Restoring a 68 SWB
tdave00's Avatar
Has this, or can this be done?
Forgive my ignorance and the lame drawing. For certain reasons I don't wanna use a panhard bar, and don't wanna spend the money to install a watts link. I was wondering if the concept in the picture has been done or if it would even work using the stock trailing arms. Thanks
tdave00 is offline   Reply With Quote
Old 08-07-2008, 01:48 AM   #2
leftcoast66
leftcoast66's Avatar
Re: Has this, or can this be done?
I don't see why it wouldn't work. So long as the uppers are a large enough angle to be able to block the back axle from going side to side.
leftcoast66 is offline   Reply With Quote
Old 08-07-2008, 02:37 AM   #3
tdave00
Restoring a 68 SWB
tdave00's Avatar
Ok, if it can be done can someone give me an idea of how far apart the bars need to be mounted on top of the axle, and how long they would need to be?
The longer the bars the less the angle will be. What is an optimal/acceptable angle?
Old 08-07-2008, 06:57 AM   #4
HotRodYJ
HotRodYJ's Avatar
Your basically looking at a double triabulated 4 link, done very often in off-roading. The only problem I see is with the stock trailing arms you have no pivot point at the axle end. It would need a bushing or heim type attachment, something that would allow the trailing arm to pivot at the axle to prevent binding as the suspension cycles up and down. You'd be better off replaceing the trailing arms with links also then it would work fine. You can do single triangulated or double trianulated either way. For a lowered 2WD truck a single triangulation is all that is needed. In off-roading where susupension travel is measured in double digits, single triangulatiion can cause some rear steering when one side is full droop and the other is at full compression. Double triangulation basically eliminates rear steer all together in these full articulation moments, but you'll never see that condition in a lowered truck.
Angle for the triangulated links needs to be about 40 degrees or greater measuring angle between the two links (so each link would angle in about 20 degrees from perpendicular to the axle)
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 08-07-2008, 09:45 AM   #5
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
You might be better off using a wishbone 3 link set up so the axle can articulate.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 08-07-2008, 12:19 PM   #6
kevindtimm
If you make a 4 link with AT LEAST a 40 degree angle between the frame and link, you don't need a panhard.
I can't draw (on the computer anyway) but I think you know what I mean.
kevindtimm is offline   Reply With Quote
Old 08-07-2008, 07:46 PM   #7
tdave00
Restoring a 68 SWB
tdave00's Avatar
Please don't take this the wrong way. I am just trying to learn. All I am trying to do is keep the axle from moving from left to right, so why would I need a bushing or heim type attachment where the stock trailing arms meet the axle? I understand what you are saying about the trailing arms having no pivot point, but this is how they function with a panhard bar. Correct? I agree with your statement that that is how it should be done because of binding, pinion angle, etc. I just don't wanna get crazy with this. I want something to replace the panhard bar.
Old 08-07-2008, 08:03 PM   #8
ripdog28
ripdog28's Avatar
Why not just go with a simple Panhard bar? so easy. What you are doing is really making more problems for later. If you want to just do something diffrent go with a 3 link and just get the center bar. this is almost as simple as a panhard bar.
Something like this is what you need. you can make one yourself if you can weld.
http://www.jegs.com/p/Competition+En...10002/-1/11319
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 08-07-2008, 08:06 PM   #9
LONGHAIR
Yes, that is how they function with a Panhard bar... The stock trailing arms don't "fight" with the Panhard bar. If you tried to use "upper" bars (like in a 4-link) they would cause a bind because they would travel in a different path. This different path cannot follow the arc of the original trailing arms unless it had a way to "adjust" its length to match...and if it did "slip", the centering effect that you are trying to achieve is lost.
The simplest way to attain this goal is a "Sliding Wishbone". It will keep the axle centered and not fight with the stock trailing arms. It can adjust it's length to compensate.
LONGHAIR is offline   Reply With Quote
Old 08-07-2008, 09:06 PM   #10
leftcoast66
Good point. I forgot about the pivot there on the lower bars at the axle...
Old 08-07-2008, 09:28 PM   #11
HotRodYJ
HotRodYJ's Avatar
Exactly. Thanks for answering.
Old 08-07-2008, 09:59 PM   #12
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I don't have all the answers on this so I hope someone with more knowledge than I will chime in and fill in as I may be creating more questions than answers...
I have begun to see 2 links in service where they have run a link from the front pivot of one arm to the rear or axle mount area of the opposite arm.
MY question is how well does this work and would it be a suitable solution for Tdave?
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 08-07-2008, 10:15 PM   #13
leftcoast66
Thats a good idea. I wonder if the factory trailing arms are strong enough to be pulled like that. Otherwise I could see that being somewhat ok for the time being type of deal. Only worry is how close they are at the pivot point on the frame.
Old 08-07-2008, 11:19 PM   #14
tdave00
Restoring a 68 SWB
tdave00's Avatar
Josh
Are you talking about something like this?
BTW...after thinking about what you guys are saying about the panhard not fighting with the trailing arms I think I understand. If I tried to use a triangulated 4 link up top I can see where that would inhibit the natural path that the trailing arms are supposed to go and create binding. I see what you mean now HodRodYJ about the trailing arms needing some type of heim joint in that scenario. Still learning. Thanks for the education guys.
Old 08-07-2008, 11:28 PM   #15
tdave00
Restoring a 68 SWB
tdave00's Avatar
Sorry, internet was acting up. Double post.
Old 08-08-2008, 12:08 AM   #16
RunninLo
RunninLo's Avatar
Exactly like that. I talked to a few guys about 2-link ing my '66 conti and that was suggested to me and I've seen more than a few using this just not sure why.
Josh
88 4x4 crew DD
Old 08-08-2008, 12:32 AM   #17
leftcoast66
Josh
Its an easier setup. I'm just worried that the fact that the mounts on the frame for the trailing arms are only 10 or so inches apart. Not positive if that will inhibit it from working or not.
Check out this thread. He used that style of 2 link w/ the bar across the back in his build.Bedsled71
Old 08-08-2008, 07:11 AM   #18
HotRodYJ
HotRodYJ's Avatar
Pro Street and drag cars are set-up this way. Not sure it provides enough lateral support for hard corning on the street but yes the concept is sound and should work.
Old 08-08-2008, 09:25 AM   #19
LONGHAIR
This would work if the front mounts were farther apart, like in a "parallel" link. It the case of the stock position, I would say no.
The only other issue is with the driveshaft. If you have a lot of suspension travel, it can become a problem... (airbags) With more of a stock travel situation, it should be ok.
Old 08-08-2008, 10:04 AM   #20
fastbagged68
fastbagged68's Avatar
Look underneath a 65-72 chevelle. They run a rear trailing arm. Also Chris Alston Chassisworks sells a backhalf kit that is that.
fastbagged68 is offline   Reply With Quote
Old 08-08-2008, 01:31 PM   #21
LONGHAIR
Yes they do.....but all of the arms pivot on both ends.
The problem here is that you cannot add "upper arms" to the non pivoting lowers, it would cause a bind.
Old 08-08-2008, 02:14 PM   #22
fastbagged68
Sorry I did not read that he wanted to use the stock arms. My bad. No you can not use upper bars but you can you a wishbone. You will need to weld a tube to your axle tubes to go underneath your rear end and fasten the one end of the wishbone to it. The other 2 ends to the front. I can maybe take pics of mine.
Old 08-08-2008, 06:05 PM   #23
Shane
Shane's Avatar
why reinvent the wheel? use what's proven and you'll be fine.
Shane is offline   Reply With Quote
Old 08-09-2008, 01:02 AM   #24
SanitysBane
Even on the Chevelles the arms bind...
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
