08-07-2008, 07:19 AM | #1 |
accelorater / gas pedal... w/ V-8
sup everyone, as you know i am putting that 50 GMC back together now. i got most "instruments" hooked up, shifter, steering, brakes. but the gas pedal i am not sure what to do. i need to keep the stock pedal but its designed to "push" the throttle, while now the V-8 SBC requires the throttle to be "pulled".
what are you guys doing to convert the push pedal to a pull pedal??? thanks! Yaril |
08-08-2008, 02:50 PM | #2 |
Re: accelorater / gas pedal... w/ V-8
ok, looked in my friends 53 Bel-air and this is similar to what he has. you push on the pedal then the top arm pulls on the cable...
http://cgi.ebay.com/ebaymotors/1965-....c0.m245.l1318 can somebody help me locate this and a cable? |
08-08-2008, 03:38 PM | #3 | |
08-09-2008, 09:35 PM | #4 |
I woud like to see what a 55-59 chevy truck looks like, any pics ??
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-10-2008, 09:46 PM | #5 |
PROJECT 7DEUCE
This is what I used in my 56... Works pretty damn good...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-11-2008, 12:08 AM | #6 |
Thanks Frenchblue. I was thinking about the mechanical linkage that is bolted to the firewall.
