Old 08-07-2008, 11:02 AM   #1
gafiredog
turbo 350
i have been told that a turbo 350 can be had with a lock up converter, and will get better mileage than a nonlock up converter. no wiring harness to install either. is this true ?
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 08-07-2008, 11:24 AM   #2
Rodms
Rodms's Avatar
Re: turbo 350
Call this number in Muscle shoals Alabama 256-383-6868 talk to Kenny,Its PTC transmissions and converters,he can tell you everything you need to know and probably build your converter for you if you already have one
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-07-2008, 05:38 PM   #3
gafiredog
Re: turbo 350
thanks, will do
Art
1975 c-10 stepper
1987 crewcab dually
Old 08-08-2008, 06:22 AM   #4
D13
D13's Avatar
Re: turbo 350
Yes, the 350 was available with lock up converter, it takes a power feed routed thru the brake pedal and if I remember the rest is in the trans. Be aware these are different than 'regular' 350's and the TCC (torque converter clutch) will not like high HP or monster torque. But for a basically stock DD driven over 45mph or so they will help your mileage ~5%
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 08-08-2008, 07:03 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Re: turbo 350
The GM 350C tranny was one with a lockup converter. They came on the Mid 80s trucks and did pretty fair jobs on their application. Most tranny shops did not want to touch them, because the output shft on them was smaller than a standard 350. The option was then to just install a 700 R4 and get lower first gear and the OD gear also.
piecesparts is offline   Reply With Quote
