08-07-2008, 05:51 PM | #1 |
Help, Vin Plate
Does anybody know if they make reproduction vin plates, I have mine but is beat up, Does match my title . Any help would be appreciated
Semper Fi! |
08-07-2008, 06:59 PM | #2 |
Re: Help, Vin Plate
No it is illegal to remove, modify or replace a vin tag. Otherwise theives could easily steal a truck and swap the VIN. If you look closely you will see they have special headed rivets that cannot usually be found locally. If your cab does not match the frame number you should check with your DMV to see what to do. In Idaho if you swap the cab you need to have a title or bill of sale for it and the frame and take the truck to DMV for inspection. The title and registration reflect the numbers stamped on the frame. When I pulled my cab I found a second serial number on the drivers side top rail I did not know was there.
08-14-2008, 12:22 PM | #3 |
Re: Help, Vin Plate
Try- Trim Tags, Ph. 847 478 8247, they have the correct rossett rivets, tags etc.
( I phoned them yesterday and they are on vacation until Aug. 18) Tom |
08-14-2008, 03:56 PM | #4 |
Re: Help, Vin Plate
Thanks, will Do...........
Semper Fi! |
08-17-2008, 07:20 PM | #5 |
Re: Help, Vin Plate
Found a place, hefty price, Data tags .com Need a copy of Title and pic of vin plate.......
Semper Fi! Last edited by Coronas56; 08-17-2008 at 07:20 PM. |
08-17-2008, 07:34 PM | #6 | |
Re: Help, Vin Plate
Please tell me where to find the VIN numbers on a 1953 chevy 1/2 ton frame.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-18-2008, 08:56 PM | #7 |
Re: Help, Vin Plate
08-18-2008, 09:03 PM | #8 |
Re: Help, Vin Plate
195.00, 5 day turn around........thinking I don't need it that bad, I have the original on my truck , but its worn. I can do a few things with 195.00......
Semper Fi! Last edited by Coronas56; 08-18-2008 at 09:03 PM. |
08-18-2008, 09:05 PM | #9 |
Re: Help, Vin Plate
These were spot welded, and epoxied. They do sell the rivits for other applications
Semper Fi! |
08-19-2008, 12:41 PM | #10 |
Re: Help, Vin Plate
Mine is so beat up and abused that it would be hard to know it was a vin tag if you didn't know what you were looking at.
08-19-2008, 01:06 PM | #11 |
Hollister Road Co.
Re: Help, Vin Plate
Trim tags does not do Vin plates
08-19-2008, 01:30 PM | #12 |
Re: Help, Vin Plate
08-19-2008, 02:00 PM | #13 |
Re: Help, Vin Plate
There are most definitely places you can buy the repro Vin plates.
1947-49: http://www.classicparts.com/1947-49-...ctinfo/33-011/ 1950: http://www.classicparts.com/1950--Do...ctinfo/33-012/ 1951-52: http://www.classicparts.com/1951-52-...ctinfo/33-013/ 1953: http://www.classicparts.com/1953--Do...ctinfo/33-014/ 1954: http://www.classicparts.com/1954--Do...ctinfo/33-015/ The only thing that would be illegal is stamping a serial number on it that wasn't the original one assigned to the truck. But for the purpose intended by the OP, these tags more than serve the purpose of replacing one that has become illegible or damaged. Last edited by robin58; 08-19-2008 at 02:02 PM. |
09-09-2009, 09:10 PM | #14 | |
______________
Re: Help, Vin Plate
09-09-2009, 10:47 PM | #15 |
Re: Help, Vin Plate
http://www.fillingstation.com/
They sell the plate, and it is very reasonable. http://www.parts123.com/parts123/yb.dll?parta~partsort Last edited by PDW HOTRODS; 09-10-2009 at 10:34 AM. |
09-10-2009, 07:10 AM | #16 |
and a few others
Re: Help, Vin Plate
I got my VIN plate rivets from them. Fast shipping and they even sent me a free hat that I wasn't expecting.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
