Old 08-07-2008, 06:06 PM   #1
notahybrid
Speedometer Cable Help
Yo, my speedometer is not working and has not since I got the truck (68 C10). I assumed that it was the missing driven gear so I got the correct one and confirmed that there is a drive gear in the transmission.
I noticed that the cable with the end going in the speedometer is noticeably smaller than the hole it goes into. I would say that the end of the cable that should be turning the gague is about 1/16" wide. Does the hole get smaller inside? As far as I can tell this is the original gague cluster, but I'm not sure about the cable. The gear did slide over the cable on the transmission end. Could there be a problem inside the gague? Do these these cables break often internally?
notahybrid is offline   Reply With Quote
Old 08-07-2008, 07:11 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Speedometer Cable Help
The cable may have woobled the gauge backside out and not doing any good inside the housing. You can buy the new cable at any part store. Get one and put it inside the gauge and see if it turns it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-07-2008, 08:13 PM   #3
68gmsee
Active Member
68gmsee's Avatar
They're fairly easy to remove, clean and lube. I did mine about 6 months ago. While it's out, you can check to see if it turns on both ends. They're pretty sturdy woven cable, but I figure it's possible to rust and break.
On mine I can unscrew the dash end and pull the inside cable all the way out of the sheath. You may be able to do the same on yours.
You can also buy new ones at local auto parts places.
68gmsee is offline   Reply With Quote
Old 08-07-2008, 09:58 PM   #4
notahybrid
Thanks gents, I'll try pulling it out and if that doesn't work I'll get a new one.
Old 08-08-2008, 09:15 AM   #5
67mater
67mater's Avatar
Since I was tearing it down soon, I didn't repalce my cable when the end was rolled. Instead, I uncrimped the end, shortened the cable abotu .25" and the sleave the same, then re crimped; worked great.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
