Old 08-07-2008, 08:09 PM   #1
68ChevyGuy
68 Rear Diff.
Anyone know what the stock gear ratio on a 68 Chevy C20 8lug rear diff is ? I heard from a few guys 4.11, which is some what hard to believe and far as I know, its the original rear end too.
1968 Chevy C20 357/350
May the crabs of a thousand Las Vegas hookers infest the crotch of the person who fu<ks up your day, and may their arms be to short to scratch.
68ChevyGuy is offline   Reply With Quote
Old 08-07-2008, 08:13 PM   #2
LONGHAIR
Re: 68 Rear Diff.
Transmission: Automatic or Stick?
LONGHAIR is offline   Reply With Quote
Old 08-07-2008, 08:15 PM   #3
68ChevyGuy
Re: 68 Rear Diff.
Originally was a manually, with a sb320.. I converted it to a TH350 and a 71-73 sb350
Old 08-07-2008, 08:34 PM   #4
haysonj
haysonj's Avatar
Re: 68 Rear Diff.
My 69 k20 4x4 had 4.09 gears front and back
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-07-2008, 09:01 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 68 Rear Diff.
what engine was in there originally?
4.09 gears.... is that listed on the SPID? I have never heard of that in a stock truck
Old 08-08-2008, 01:56 AM   #6
Classic Bowties
Always on the hunt...
Re: 68 Rear Diff.
Its a K series deal as I have seen several original 20's that have had one of those small oe type metal Id tags (stamped 4.09) hanging from a diff. cover bolt on their front 44's, I am pretty sure I have a 71 K20 in the yard that is still wearing that tag, and if so I can get a pic. in the am. I am thinking if marked with the 4.09 tag up front then they left the factory with 4.10's out back, IIRC.
Classic Bowties is offline   Reply With Quote
Old 08-08-2008, 02:26 AM   #7
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: 68 Rear Diff.
C20 standard was 4.57, Longhorn was 4.57, C20 panels and subs were 4.57, K20 front was 4.55...rear 4.57, K20 panels and subs were the same as K20 pickup. The 396 option got a standard 3.54 Dana. 4.56 Dana was used with the optional leaf spring rear suspension option on other displacement options. At least that is what the 1968 GM Restoration Guide states.
4.10 ratio appears to be the only C20 optional rear axle ratio and it was not offered for the 396. The big block only came with a 3.54. There were no optional ratios with the K20's either in '68. Other years are probably different.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-08-2008, 02:40 AM   #8
68ChevyGuy
Re: 68 Rear Diff.
Thanks for the info, big help!
Old 08-08-2008, 08:31 AM   #9
haysonj
haysonj's Avatar
Re: 68 Rear Diff.
I probably should not have responded to his post as my truck is a morph. It does have a tag on the front Dana 44 that reads 4.09 and I changed the rear end so I could match the front. the spid in the original cab was painted over but the truck had a 350 in it when I bought it.
