Old 08-07-2008, 11:12 PM   #1
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Unhappy In need of help How to change Steering Column Floor-Seal
Ok I bought a new Steering Column Floor-Seal The rubber pice that goes on the steering column and through the firewal I Thought it would be easy to change I took off the retainers at the bottom.. What else do I need to do I have no Idea how the rest comes out it is On my 72 It has a Tilt Column... Any pictures would be great... Thankyou in advance guys I know I can depend on you ....Here are some photos...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 08-07-2008, 11:29 PM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: In need of help How to change Steering Column Floor-Seal
Steering column will have to be almost completely disassembled. If you do not have the know how to take it apart there is a cheaters way. The lever for the linkage at the bottom of the column can be bent down enough to slide the seals over it. Then just simply bend it back up. This is not the correct way but it does work.
KevsClassics is offline   Reply With Quote
Old 08-07-2008, 11:43 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Bend the lever and stretch the gasket...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-08-2008, 01:03 AM   #4
petey-pablo
"THE GREEN GOBLIN"
Will bending the lever weaken it ?
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 08-08-2008, 01:17 AM   #5
KevsClassics
TILT COLUMN GURU
Yes but it will take several bends before it breaks. So if it has not been bent before you will be ok. I have done this before for guys who did not want to pay the labor to do it the correct way.
Old 08-08-2008, 04:08 AM   #6
petey-pablo
"THE GREEN GOBLIN"
So Do I have to pull the steering wheel off then is that the next step I realy dont want to Bend the lever! Thanks guys!
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 08-08-2008, 06:15 AM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
In my opinion, if you don't want to bend the arm....then everything that is a larger diameter than the hole in the gasket/seal, or protrudes from the column will have to be removed. Steering wheel, shifter arm, turn signal arm, the bell beneath the steering wheel that houses the tilting mechanism, etc.
Member Nr. 2770
Old 08-08-2008, 07:56 AM   #8
Andy4639
Old member
Andy4639's Avatar
My factory tilt wheel for a floor shifter didn't have all that stuff on it. Slide right off. Ha!!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-08-2008, 01:06 PM   #9
nyncompute
nyncompute's Avatar
Ok as I recall, I left the seal out in the desert sun to soften it, put it on as far as I could protected the seal with a rag, got some vice grips with a good hold on it and while bracing the column, I stretched it over the arm. It returned to its shape just fine. Maybe I got lucky though.
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 08-08-2008, 01:29 PM   #10
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: In need of help How to change Steering Column Floor-Seal
It will stretch over the lever without bending it, I have done this four times now and it has worked everytime!!!!!!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 08-09-2008, 04:34 AM   #11
petey-pablo
"THE GREEN GOBLIN"
Unhappy Re: In need of help How to change Steering Column Floor-Seal
This sounds good I will give it a try but have you chaged the smaller seal the one that goes in the cab end of the steering shaft it is smaller? I figured if I was going to change one why not change them both thst one is cracked as well!
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
