Resident of Here
Posi
Whats a good posi-trac that fits the 12-bolt GM rear? 3:42 or 3:73 please
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
67-72 Addict!
Re: Posi
Eaton
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Re: Posi
posi's dont come with gear ratios you need to get gear sets for a gear ratio
2WD Jimmy
![]() Join Date: Mar 2005
Re: Posi
Depends on what you are doing with it. If you want a posi...then Eaton or auburn. 4 wheelin, Air locker. Burnouts,, Detroit Locker, or youll toast a posi unit.
Re: Posi
I put a eaton posi in my 72 GMC and I liked it, so I got another one for my 68. You'll need to decided what gears so you can get the right posi though. I think 3.73 and up is a series 4, and below that is series 3.
In my jeep, I had a eaton true trac in the front diff and it was OK. I had a ARB in the rear and it worked well as long as the compressore and air lines were in good working order. |
Re: Posi
anything but a gov lock...
Resident of Here
Re: Posi
Does anyone sell a posi and gear kit?
Questionable
Re: Posi
i give away gov lock rear ends
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Re: Posi
shifty i would like its now gone.and i will come and pick it up
Questionable
Re: Posi
it's yours if you want to swing by. you gotta take it with the rear-end housing (has hanger/leaf mounts hacked off).
if you want the 5-lug axles that came with it, you'll need to kick me $50. gimme a holler. there are pics of this rear end floating around somewhere. it has 3.43 gearing IIRC. i forgot - let me find the post with pics.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 08-11-2008 at 12:43 AM. |
Questionable
Re: Posi
hear are pics of the gears: http://67-72chevytrucks.com/vboard/s...47#post2608447
everything should be in there with all shims, etc, but i would recommend pulling it apart and rebuilding it just because it has a decent # of miles on it. it's a G80 govlock unit 3.40 gear ratio, from what i could gather.
Resident of Here
Re: Posi
I'll keep looking or bring it to a local shop and have them do it. Sorry I couldnt get it from ya shifty, too far of a drive also.
#13 |
Re: Posi
I`ve had good luck with the Gov-Loc in my`91 Suburban SF 14-bolt with 35" mud tires.So, far it`s kept me from getting out to lock the hibs.They aren`t for extreme use.But,work for the way the factory intended.
My advise would be to keep an eye out for a complete factory posi rear you can bolt right in. With buying a posi unit to install,I see you understand that it has to be from the right series carrier assembly since they transition break falls in at 3.73.But,a 3.73 could be had in either series,I believe.So,you gotta what that.Buying a whole rear is the way to go,IMO.The labor you`ll save will be equal to the cost of the rear.
#14 |
Resident of Here
Re: Posi
You guys know I want this for a 2wd right?
#15 |
Re: Posi
GOV lock? Explaination? I've never heard this term used...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
#16 |
Re: Posi
do u still have it shifty
#17 |
Re: Posi
I used Auburn posi with 3:48 and no trouble for the last 2 years.
#18 |
Re: Posi
#19 |
Re: Posi
I have a few of those boat anchor pics too....
#20 |
fugedaboutit
Re: Posi
That'll buff right out! LOL
Richmond makes 3.73, 4.10, and 4.56 rings for 3 series carriers.
Currently truckless ![]() |
#21 |
Questionable
Re: Posi
Question for you two with grenades:
1) How much horsepower did you have jamming into these things? 2) What was the truck used for, and what were you doing when it grenaded?
#22 |
Re: Posi
Ive never owned one, those were pics from a google image search for "gov lock"...
#23 |
I have a radical idea!
Re: Posi
I have an Eaton and an Auburn carrier that looks just like those. I agree with Special K, the Gov Locks are fine for stock or mild applications, but will not withstand exteme useage. With that being said, there is a lot of stress on the rear end parts, and even the best stuff can fail in seemingly "easy" situations. I ran in the mid 11's pulling 1.59 - 1.61 60ft times forever (over 80passes) with stock "weak" axles in my '82 Z28 praying each time that I wouldn't pop one. I finally got up the money and upgraded to some nice "strong" Strange axles, made 6 passes and broke the one on the passenger side on the launch. Go figure, huh?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#24 |
Re: Posi
I will order a powertrax very soon.
#25 |
Re: Posi
So basically I've gathered that Gov-Loc=BAD!!! It's just a goofy type of posi then..?
