![]() Join Date: Oct 2006
Thinking of a 4spd
I have a chance to get a 4spd Sawgina that came out of a 69 chevelle. Any tips or pros and cons would be great Also is 200.00 good price ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 08-08-2008 at 01:12 PM. |
Re: Thinking of a 4spd
Is the saginaw the same as the munci 4 speed? If so, then I would jump on it for $200.
![]() Join Date: Mar 2007
they aren't very strong, but if you don't have a lot of power or beat on it they hold up alright.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4 |
My truck has a slightly warm L6 250
and is more of a cruiser,then a bruiser. So it should be fine ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 08-08-2008 at 04:10 PM. |
Hey Y'all!!
A saginaw should be fine behind a L6. As for the price, if it's a good running tranny(synchros are ok, no noises, etc.) it doesn't sound bad to me.
If you have a cruiser, have you considered the advantage of getting a transmission with an overdrive? The T-5 conversions are discussed if you search the archives. The non world class t-5's from and S-10 would work well behind your inline 6. Also, inliners.org has a tech write up on them that is very good. The Saginaw that you are looking at will still be a 1 to 1 ratio in fourth the same as 3rd in your 3 speed. You will only be picking up a bit closer spacing between gears but pretty much starting in first and ending at fourth in the same place with both transmissions.
Just food for thought. If you go with a T-5 you need the older ones from the late 70's that have a manual speedo drive. Pick and Pulls have these pretty regularly on the cheap. Regards, Steve New Orleans |
They are not the same as Muncie. Muncie has spur cut gears and an aluminum case, they were made for light vehicles with big horsepower motor, given a choice between the two in a truck I would rather have the Saggie for the cast iron case. It's not for big block torque but holds up fine with stock small chevy V8 and L6. I have two 4 speed Saginaws, how about $150 for the good used one and $400 for the one with new synchros, bearings, seals and a Hurst Competition plus shifter? I'm in Chico
