Old 11-14-2002, 03:25 AM   #1
whitdog72
Question Somethings crapped in my heater wiring ?? ned some help
k i have a 91 chevy, it has the electronic display for the heat and a/c....
story goes: driving with the a/c works great, heater works everything is good, park truck, shut truck off, come back in half hour to go to lunch display no longer works, and its just the display, i tried another display module and didnt work either. I took my idiot light and tested my incoming power and there seems to be power there on the few incoming power i also checked the grounds they seem good. Now i went to the dealership and he said there are 3 like module or capacitors or somthing in the dash and one of them could have gone out thats why the display dont work not enugh power..... so the dealership wants to much to fix it, ANNNNYONE have this problem before and fixed it themselves..........please help i'm freezin my a$$ off!!!!!!!!!!
whitdog72 is offline   Reply With Quote
Old 11-14-2002, 09:52 PM   #2
Piston
Piston's Avatar
Did you replace the hvac controller with a NEW one or another used one? This type of controller had quite a few problems thats for sure. "MOST" display problems result in a failed controller.
A few times I have seen the blend door actuator short out and cause the controller to show bad (display going crazy). Or in other cases the recirculation door motor gears strip out and you hear the buzz on startup and shutdown.
These aren't a very complicated circuit really... not like they are making it out to be.
If you replaced it with a new unit and its still doing the same thing, shoot me an email. I'll send you some literature on what steps to take next.
Piston is offline   Reply With Quote
Old 11-21-2002, 01:14 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I had a similar problem on my 92'. I disconnected my battery for a few minutes and problem solved after computer was reset.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-21-2002, 02:58 PM   #4
whitdog72
Thank 70c10 i'll give that a try, didnt think of that, i have looked into those acuators and all but i'm so poor right now i cant afford to pay attention!!
thanks for the help guys
72 LB 4inch lift 33's 350/350t stage 2 shift kit
91 chevy 4inch suspension lift, 3inch body, 33inch swampers, chipped, stage 2 shift kit ( it kicks hard!), 4 JL audio W0 10's behind my seat,
and also my 72 cj5
AIM: whitdog72, FORDSSUC
