08-09-2008, 06:54 PM | #1 |
Not too old to learn
How best to short drop
My 68 C10 has coils all around. I want to drop it just a little, couple of inches only, mostly to fill in the gap between tires and wheel opening. I want to use same size tires front and rear....maybe:drama
Sorter coils ? or What.
1968 C10 a way to long restoration. |
08-09-2008, 06:55 PM | #2 |
Re: How best to short drop
Damn wish I could spell sorta coils? Oh ya maybe bags? nope .
SHORTER coils
08-09-2008, 08:14 PM | #3 |
Your front drop options are drop springs, drop spindles (req's disc brakes), stepped a-arms, or cut the stock springs (free & easy). Trimming 1-coil off the stock coils yields a 2-3" drop up front.
For a rear coil suspension, your options are shorter drop (or swap) springs, lowering blocks (up to 2" on the blocks w/15" wheels); or bags. Bags are a good option if you know you're going to work the truck hard & they can be done for about $200 (rear only) if they're manually filled. Pick the options that suit your plans the best & we can help you w/the specifics.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-09-2008 at 08:14 PM. |
08-09-2008, 08:35 PM | #4 |
Any disadvantage to cutting a coil out of springs? Dose that affect the compression rate. As in stiffened them up a bit?
08-09-2008, 08:53 PM | #5 | |
One coil trimmed has worked on all my vehicles for moderate lowering since the mid 80's so you should be ok. If you don't care for the ride, you're out nothing & can still get drop springs.
08-10-2008, 02:40 PM | #6 | |
08-10-2008, 04:13 PM | #7 |
That's why the rears require the different approach. You can't just cut the springs like you can in front.
08-10-2008, 05:46 PM | #8 | |
Anyway I think I'll research the new coils that are dropped. Any sources to consider?
08-10-2008, 07:08 PM | #9 |
Guys have used Chevelle / Malibu springs in the rear with mixed results ... some claim 3-4 inches of drop ... some claim no drop ... I have a set of Chevelle springs that I bought to experiment with but got rid of the "test" truck before installing them. I'll let you have them cheap if you're interested.
08-10-2008, 07:44 PM | #10 | |
08-10-2008, 08:09 PM | #11 |
One day...
Joe231 has a set of jeep springs under his 66, he said it dropped it a bit.
08-10-2008, 08:17 PM | #12 |
yeah, i got right around 4 inches using the jeep coils and removing the coil over shocks that were on the rear.
here is my thread LINKY do a search for jeep coils, there are several threads about it
CHEVY ONLY Last edited by joe231; 08-10-2008 at 08:18 PM. |
08-14-2008, 04:56 AM | #13 |
Man it would probably be best to just go to cpp, ece, or somewhere like that and order drop springs. You have to remember all of these others are old springs and it wouldnt hurt to replace them and its not too expencive to do.
