Hey guys, I swapping in a 2004 5.3 LSx engine in my '69 C10 with factory power steering. I have the late model power steering pump and high-side hose. What do I need to adapt this hose to my factory power steering box high-side port?
Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
Old member
Re: Late Model Power Steering Hose Help....
Take both hoses to a NAPA store or a hydrolic hose store that makes them they should have no trouble making you the hose.
You will need the hose end that fits your steering sector and the end that fits the newer pump.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Hellasick
![]() Join Date: Jul 2006
Are you talking about using a metric/o-ring pressure line on a flare box? if that is the case, you can just pop out the brass flare fitting in the pressure box. Use a punch that will fit into the hole in the fitting. The threads are close enough to work just fine. Found out about this trick from JR Motorsports in Ankeny, IA.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
#4 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Hellasick
Don't have any pics, not sure where my old junk car PS box is, cause I popped the fittings out to try it. There are no new parts involved.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys Last edited by 70C10Toejam; 08-10-2008 at 08:58 PM. Reason: link became irrelevent |
Hellasick
Found the PS box, so I did this little change...with pics.
1st pic is the box unchanged. 2nd pic is with the brass fitting removed and a metric/o-ring pressure line ready to go in. 3rd pic is that line screwed into place.
I ended up just having a new hose made since the late model factory hose was way too long. A local shop took care of it in a few minutes for $20. They even installed swivels on both hose ends and attached the hard lines to the swivels.
