Old 08-10-2008, 01:38 AM   #1
Green Machine
Green Machine's Avatar
Loose shift lever pin on factory tilt - how to fix ?
Factory tilt from a 72 we put in our 71. The pin that holds the shift lever in is loose in the shift socket, won't hardly stay in. Looks like small knurling at the top is all that holds the pin in, and the shift socket is worn just a hair to big.
JB weld ? (just a little bit on top) or ??? A manual tran 3 speed uses a roll pin setup, can a tilt be modified to use a roll pin ? This is a nice column, we just had it all apart to replace the turn signal switch and clean and paint it so I would like to save it if at all possible. Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-10-2008, 02:32 AM   #2
SactoJim
SactoJim's Avatar
Re: Loose shift lever pin on factory tilt - how to fix ?
I have the same problem.....I'll be watching this post.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 08-10-2008, 03:22 AM   #3
Andy4639
Old member
Andy4639's Avatar
Why not take it out and replace the pin with a new one? That should tighten it up. If the lever is not tight then try some small washers that will fit the pin diamter to take the slack up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-10-2008, 09:25 AM   #4
Green Machine
The pin is just fine, tried another pin from a regular tauto column and didn't change anythng. The hole for the pin in the shift socket is worn loose at the top.
I think the non-tilts are setup the same way too, should be someway to fix these properly, I mean I could stick a bolt and nut through there but thats just not right.
Old 08-10-2008, 09:50 AM   #5
Husker
Husker's Avatar
How about a brass bushing, you may have to drill hole for bushing but it would tighten it up. If it loosened up again you would just have to replace the bushing.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 08-10-2008, 09:54 AM   #6
teeitup
Just like to part out trucks!!
teeitup's Avatar
I had a guy put a roll pin in mine, its working fine right now, but I don't know how long it will last. Good luck, Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 08-10-2008, 05:12 PM   #7
truckdude239
truckdude239's Avatar
weld it up and redrill it?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-10-2008, 05:46 PM   #8
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
There is no correct way to fix that you will have to replace shift bowl.
KevsClassics is offline   Reply With Quote
Old 08-10-2008, 07:46 PM   #9
berencam
berencam's Avatar
I took a small bolt and a nylon nut and attach it that way. i just took the bolt and cut it down to the exact size i needed. Took up all the slack in the shifter by tightening it.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 08-11-2008, 03:24 PM   #10
Hart_Rod
Hart_Rod's Avatar
If I'm not mistaken, one of the board vendors sell and oversized pin to fix this. GMCPauls? WES? CLASSICHEARTBEAT?
Hart_Rod is offline   Reply With Quote
Old 08-11-2008, 08:47 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
WES? CLASSICHEARTBEAT? We are the same... I just changed my board name to match my business. I don't know of anyone who is selling oversize pins for this application. We have a few stock (NOS) pins in stock. Could be the pin that is the problem or it could be the housing. If you are taking one 40 year old pin and comparing it to another 40 year old pin, you could get the same result though. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-12-2008, 11:12 AM   #12
Hart_Rod
Hart_Rod's Avatar
OOOOPPSS!!!! That was a double plug for you Wes, . Maybe I'm getting senile, but I could of sworn some one was making these......If not, will I get some royalties if someone starts making them?
R/
Old 08-12-2008, 02:36 PM   #13
Luvlegs
Luvlegs's Avatar
how about expoxy in the hole, LIGHTLY coat the pin with grease/pam or something similiar - when it cures, you can still remove the pin but the expoxy will have the flutes of the pin imprinted in it....
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
