? on Max tire size for stock 81 K5 4x4
Hey guys and gals,
I'm going out to get mudders today and I was wondering if anyone can tell me what's the max size tires I can get on the 15x8's without tearing up the sidewalls. I'm pretty sure 31x10.5's will work no problem. Anyone running 32's or 33's. I've got the heavy duty suspension with a pair of shocks on each side on the front. I got a few responses on the 73-87 message board but I know you guys have several trucks.
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch 1995 T10 Blazer 4.3L 4x4 (Son's) 2004 GMC Envoy 4.2L 2WD 2005 GMC Sierra Crew Cab Z71 4x4 5.3L 240 Fun Finder Travel Trailer Harvest, AL 35749 |
Getting cabin fever?!?!?!
i knew a guy who had 10 inch wide rims and could run 33"s with no lift, but they rubbed really bad. a 32" should fit with minimal rubbing if you backspacing is right. otherwise just throw a 4"inch lift kit in and never worry again!
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic |
All trucks are a little different, but 32X11.50s on an 8 inch rim will fit fine on pretty much all trucks. Might be able to make them rub a little when REALLY twisted up and turning sharp. 33X12.50s (on the 8 inch rims) will work fine on the road on most trucks, but will also rub a lot sooner on most trucks off-road. Some people run the 33s and claim no rubbing.
Tim |
