08-10-2008, 08:15 PM | #1 |
Convert an auto tilt to a manual tilt
Is it possible to convert an auto tilt to a manual tilt?
Does anyone have advice or instructions on the process?
1971 Chevy SWB 4x4 1971 Chevy LWB 2003 Duramax |
08-10-2008, 08:18 PM | #2 |
Re: Convert an auto tilt to a manual tilt
sure, grind off the parts and add some JB weld.. then smooth it, add a little filler, sand and paint.
Or spend $400+ for a new tilt...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-10-2008, 08:22 PM | #3 |
If you are thinking of a tilt with a shifter on it for a (3) speed then probably not. Converting it to a column for the manual floor shift can be done.
Which one are you thinking of wanting to do? Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-10-2008, 08:25 PM | #4 |
Old member
Here is a manual tilt for sale. It's not mine I'm just using the pictures that others posted.
Here are some pictures of a auto tilt. See the differances in them. The top is a easy fix body filler or weld it up and smooth it out. The bottom can be left as is or cut it all off.
08-10-2008, 08:42 PM | #5 |
Floor shift for a 4 speed manual.
08-10-2008, 08:44 PM | #6 |
I see what your sayin Andy, is it really that easy?
08-10-2008, 08:53 PM | #7 |
Old member
YES
You don't even have to cut the bottom part off if you don't want to. I bet you could find someone who would trade you for it if you wanted to. The top part could be fixed very easy if you can weld or have someone do it for you are just leave it alone in cae you ever went back to a Auto. I just took mine out and painted it last week. It is a manual shift also.
08-10-2008, 09:25 PM | #8 |
There was a website that made a collar for it, not sure that it would look that good though
08-10-2008, 10:47 PM | #9 |
Old member
Check this out on doing a tilt.
http://www.customclassictrucks.com/t...c10/index.html Found this on E bay. Doing a tilt wheel is cheap. http://cgi.ebay.com/ebaymotors/67-72...spagenameZWDVW
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 08-10-2008 at 10:59 PM. |
08-10-2008, 11:05 PM | #10 |
I was kinda thinking the same thing Andy, see I current dont have a tilt column of any kind. It seems that it is easier to find an auto tilt vs. the floor shift tilt, so thats when I started looking into modifying an auto tilt.
08-10-2008, 11:10 PM | #11 |
Old member
I understand completely. Get a 78 van tilt and your set. You will have the bigger diameter shaft plus they are cheap compared to a 67-72 tilt. Follow the link I posted and your good to go.
08-10-2008, 11:50 PM | #12 |
See thats what I love about this site, we all have that same passion about these old trucks. The way everyone interacts with each other as if they were all old friends.
08-11-2008, 01:16 AM | #13 |
Old member
That's what it's all about. Helping each other! Not how much money I can make!
08-11-2008, 08:08 AM | #14 |
I am using a van tilt and modifying it...
I just got luck enough to find a board member selling all the needed parts from a manual tilt to convert it.
08-11-2008, 09:02 AM | #15 |
I used a van tilt from a middle 70's. Easy install. Hardest part was the pins in the lower shaft had to be taken out to shorten it.
08-11-2008, 12:25 PM | #16 |
wanna be 67
what a great idea for someone to do .......put in the FAQ a how to convert a auto tilt to a manual tilt!!
12-30-2008, 01:24 PM | #17 |
ok, started doing this today... of course I didn't take pictures but will bactrack and document it a little better....
