Old 08-10-2008, 09:00 PM   #1
GMC65Guy
305E & Holley 500 trouble
I put on my holley, no issues there. It starts and runs fine idling but when i drive it somewhat putts. It is getting to much fuel and running rich/blowing black smoke/ wont go over 40 because of it.
The instructions basically say that the carb. is set at the factory and shouldnt need to be adjusted.
What should I do?
This is the carb.
http://www.holley.com/0-4412s.asp
GMC65Guy is offline   Reply With Quote
Old 08-10-2008, 09:22 PM   #2
ed2552
ed2552's Avatar
Re: 305E & Holley 500 trouble
Check timing, and make sure distributor, cap, rotor, (points?), plugs, and wires are all up to the challenge.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
