Old 11-14-2002, 11:45 AM   #1
70sChevys
New Carb Time??
About a month ago, my truck started running rough when I started it up first thing in the morning...sounded like it wasn't getting gas, so I popped the hood and found the carb was leaking from the top and the front two bolts were loose. (It's a Q-jet)....this fixed it and I drove off. This morning it did the same thing and tightening the bolts didn't help....it wouldn't start. I'm going to try and prime it to start it and check the other bolts, but I'm wondering if there's anything else easy to replace that will solve the problem...if not I'm gonna get a 1406 Edelbrock for it.
So for you carb guys....what can I check to fix it (I could really use the $250 elsewhere!).
Kelly C. Hanna
MMCC & Southern Bowties Club
Hanna Woodworks
Classic Chevy Country
70sChevys is offline   Reply With Quote
Old 11-14-2002, 12:52 PM   #2
BigRed
Sorry, I'm dumb when it comes to carbs. I've seen that Jegs sells rebuild Edelbrocks for $180. Here's the link.
http://www.jegs.com/cgi-bin/ncommerc...13&prmenbr=361
It will save you about $60. I'm thinking about replacing my Holley down the road and will definitely look at this option.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 11-14-2002, 01:09 PM   #3
70sChevys
I tried the truck again when I got back home and it started fine....the bolts seem to work loose....maybe I should get lock washers for them...
Thanks for the link to the reman Edel's...we've got a speed shop down the street that has 'em as well...good thing to know.
Kelly C. Hanna
Hanna Woodworks
Old 11-14-2002, 01:39 PM   #4
ocbaud
Garage Queen Material
speaking of new carbs...
every time i stomp on the gas when i'm already rolling, my carb cuts out for a second and then gets going. does it need rebuilt or something? i know its not getting caught up on anything, so thats not it
ocbaud is offline   Reply With Quote
Old 11-14-2002, 02:05 PM   #5
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Eric sounds like you need to get teh iar mixture set. It may be bogging it down in back 2 barrels when you get on it and it's dumping too much fuel for the engine until it sucks enough air to mix in with the added fuel. I bet Swervin can tell you exactly how to fix it on a Q-jet.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 11-14-2002, 02:43 PM   #6
ocbaud
yippie now i get to adjust my timing and carb
