![]() Join Date: Jan 2002
ground question
I was putting my cowl on my 70 chevy truck today. When I put the cowl over the windshield wiper mounts it had a little spark and it also had a little spark when I put the screws in. The battery and the radio antenna were still hooked up also. It did not spark after I put the side bolts on. Is this right or do I have a ground problem. Thanks.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Active Member
![]() Join Date: Jul 2007
Re: ground question
Not normal... Sounds like you may have short somewhere. First thing I'd do is get a meter and take a reading between those points where you saw the spark and ground. The frame, body and engine are all ground and should be the return for the battery.
its all about the +6 inches
Re: ground question
the radio probably has a bad ground.
The ant has a ground in it, and as soon as you touched the cowl to the body, it grounded... which causes a spark. |
