Old 08-10-2008, 10:40 PM   #1
19GMC63
19GMC63's Avatar
found a T5... got some questions
I'm going from a SM465 to the 5-speed, so everything is pretty much straightfoward. I'll use my 4spd bellhousing so I'll keep my mechanical clutch. A new 10.4" clutch kit is on it's way to adapt the 26 spline input shaft. So my questions go out back to the output shaft.
I can't use my current yoke correct? I've found that T5's are 27 spline, but I can't find what SM465s are. If not, what yokes will work?
As far as driveshaft goes, what should I do there? I know it has to be shortened quite a bit (actually I'm gonna get a new one made) I just don't know what style u-joints it's using now. All I know is the rear end is a 10 bolt out of a 80s 1/2 ton.
19GMC63 is online now   Reply With Quote
Old 08-11-2008, 12:04 PM   #2
oldblu65
oldblu65's Avatar
Thumbs up Re: found a T5... got some questions
GMC , go to www.inliners.org , You can find lots of info there on T5 swaps . In fact , they have a T5 page which is very informative ! Check it out , Good Luck ! P.S. - Congrats on finding a T5 as I've been looking for one for a long time with no luck so far ! I'm not giving up though .
oldblu65 is offline   Reply With Quote
Old 08-11-2008, 02:31 PM   #3
19GMC63
19GMC63's Avatar
thanks for the link. After doing more research, I found the HAMB had A LOT of info too.
So tell me if i'm right, 27 spline yokes were used on GM's, 28 on Fords. So I can use any tranny yoke from a TH350, M-21, PG, T10, 4l60, T56, ect. right?
Now, I'm still confused on what u-joint style to use.
Old 08-11-2008, 03:20 PM   #4
joe231
joe231's Avatar
man I love your avatar!!!!
CHEVY ONLY
Old 08-11-2008, 11:27 PM   #5
PrerunnerRob
PrerunnerRob's Avatar
Dont know if this helps, but....
What is the difference between 1310, 1330 and 1350 Series?
The "series" of a driveshaft or universal joint is determined by the actual dimensions of the u-joint. While the front and rear u-joint can be of two different sizes the shaft is only as strong as the smaller one. The 1310 series u-joint measures approximately 3 1/4 inches wide. The 1330 and 1350 both measure approximately 3 5/8 wide. The 1310 and 1330 series can have cap diameters of 1 1/16 and/or 1 1/8 inch or a combination of both sizes. The 1350 series has a cap diameter of 1 3/16 inch and the body and journals are bigger than the 1310 or 1330. Remember 1350 is almost never found in production car driveshafts.
PrerunnerRob is offline   Reply With Quote
Old 08-11-2008, 11:42 PM   #6
19GMC63
19GMC63's Avatar
that's exactly what I needed to know, thanks a bunch.
So first, I need to measure my current rear u-joint and match the series to a front yoke so I can keep my current rear end yoke and use one type of u-joint on the driveshaft. I know it's a mouthfull, but I think I got it now.
thanks Joe!
Old 08-11-2008, 11:54 PM   #7
joe231
joe231's Avatar
Originally Posted by 19GMC63 View Post
thanks Joe!
yeah man, i need to do some research an try to learn how to do that, so cool,
i just sit and stare at yours
CHEVY ONLY
