Old 11-14-2002, 12:21 PM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Brights don't work?
Quick question, my brights stopped working, dims still work, I replaced the dimmer switch thinking that was it but didn't help. Is it the headlight switch?
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 11-14-2002, 12:58 PM   #2
ckhd
ckhd's Avatar
Check the connector that plugs into the dimmer switch for corrosion/loose wires. Even jump the terminals to see if it will work.
I had my brights stop working, and it was a poor connection there.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 11-14-2002, 06:17 PM   #3
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Same thing happened to me. Years of mud and salty slush eat away at those connections.
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 11-14-2002, 06:50 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
Yep, same thing happened here as well.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 11-14-2002, 09:08 PM   #5
nroden
nroden's Avatar
Mine was like that when I replaced the dimmer switch. The connector terminals weren't as tight as they should of been. So I bent on them a little bit to make them tighter. Kinda like when a household electrical plug gets bent and you have to bend them a little to make them fit.
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
