08-11-2008, 11:22 AM | #1 |
Lowered in Cleveland
removing trailing arm bushings
Can someone shed some light on how to remove the old bushing out of the trailing arms. Thanks in advanced.
11-19-2008, 03:13 PM | #2 |
I wish I was a cowboy
Re: removing trailing arm bushings
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
11-19-2008, 04:11 PM | #3 |
If reusing the metal shells to run poly bushings, use a torch. Let them burn a little, then dig out the crusty rubber bits. If you are replacing with stock replacements drive them out with a press, then press in the new ones.
Chop |
11-19-2008, 04:54 PM | #4 |
One day...
Torch, socket to fit the steel sleeve and a bfh thats how we got a buddy of mines out, i dont think we used steel sleeve over though.
11-19-2008, 05:30 PM | #5 |
Its Deja Vu time again
When I replaced my ends near the axle. I took a drill with a really small bit and drilled around the inner sleeve 5 or 6 places almost like a star. Then after the holes where in I took a small torch and heated up the rubber some and hit the sleeve with a socket and a hammer and it came right out. There wasn't any rubber to clean out since I didn't rely on the torch.
Why drill I thought well maybe the flame can cook through the holes and it seemed to work pretty well. |
11-21-2008, 09:53 PM | #6 |
I did get them removed, I burned the bushing out, then I used a sawza and cut through the metal outer shell, then I pounded it till it was out. The new ones were in seconds flat. Thanks for all the help.
