08-11-2008, 05:53 PM | #1 |
"THE GREEN GOBLIN"
Need help with TH400 Oil pan swap!
Ok here goes this may sound silly but I just bought a new Aluminum, Polished, Finned Pan with drain plug and a new filter kit for my TH400! I will be changeing this out myself and I have never done this is there anything I need to know before I go in to it and take it apart? The new pan came with a rubber seal and the new filter came with a cork type seal and a rubber O ring I still don't know where the O ring would go maybe Because it goes inside I will have to wait and see. NOW the question is wich should I use For some reason I don't think I am supose to use both the rubber seal and the Cork one what is best? Should I add suome Silicone around the seal as well thatnks guys for the help!!!!!!
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
08-11-2008, 06:37 PM | #2 |
"THE GREEN GOBLIN"
Re: Need help with TH400 Oil pan swap!
Anyone any help? I will dive in to it then I will come back inside in an hour to check up on this thanks guys...I am just more curious to what gasket to use rubber or cork I don't know do I have to use both?
Petey-pablo
08-11-2008, 06:41 PM | #3 |
you should use the cork gasket only, and put some silicone on it as well.
08-11-2008, 06:48 PM | #4 |
Old School, New Style
I would not use the cork. I use the rubber ones whenever I can. If you over tighten the cork its pretty much trash. The rubber one is more forgiving. The o-ring is probably for the filter, not sure as I have not changed a 400. My experience is with 350's
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
08-11-2008, 06:54 PM | #5 |
Sir, I would suggest using the cork/ composite gasket. I would put a light coating of grease on the pan surface just to hold the gasket in place. I would not use silicone sealer or cement since even the smallest amount inside the casing could damage the transmission. Best of luck.
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 |
08-11-2008, 06:57 PM | #6 |
X2 on the cork gasket works well just watch the torque it doesn't take much to damage the gasket....the o ring goes on the filter tube.
08-11-2008, 07:38 PM | #7 |
Do you have any extra cardboard to lay down? If you don't have a drain plug it can be a mess when you drop the pan. I remove all of the bolts except for 1 side so the pan will tilt and drain to one side.
08-11-2008, 07:49 PM | #8 |
"THE GREEN GOBLIN"
Ok guys thanks is the filter supoes to be loose or is there a washer missing on the bolt that holds it? it just seems to rest on the filter it wiggles and jiggles?
Petey-pablo
08-11-2008, 07:53 PM | #9 |
"THE GREEN GOBLIN"
I found that out the hard way ! I pulled the trannsmission dip stick out and whala All I know is more than a quart of oil was all over the floor well at lease it looked like more than a quart !! but the tranny had time to drain well I had to motor out so it was pretty much drained when I too the pan off thanks for looking out!
Petey-pablo
08-11-2008, 08:03 PM | #10 |
18 Till I Die
OK take that cork gasket and file it under "G" They are no good. Drop the pan and fluid. Take out all the bolts cept on in the corner. Then loosen the last one and the pan will tilt dropping the messy fluid in you drainer. Cardboard is a good idea it catches the rest of the drips. Let it drip for awhile, it helps. Remove the filter and you will see where the spout goes into the tranny, there is a oring there, sometimes a metal ring seal. Did you get both? or just the o-ring?. Stick your finger in there and pull it out if it doesn't come with the filter. Ring seal needs to be pryed out and new one tapped in with a socket. Wipe both surfaces clean. Use alcohol or brake clean. and then put the pan and new gasket on. Don't over tighten or the gasket will slip out. If there is oil on the surface then it will squish out easier. That's why they have to be clean and dry. Add about 4 quarts and run the engine. Check the level after you ran through all the gears with your foot on the brake. Then recheck. It will be cold so add till its at the bottom of the add mark or below then run/drive the truck till hot then recheck. I went out and bot some nice stainless allen head bolts to finish the pan off nice.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
08-11-2008, 08:04 PM | #11 |
18 Till I Die
Yup thats the way it is.
08-11-2008, 08:26 PM | #12 |
wouldn't happen to have a picture of the valve body without the filter on it would you?
08-11-2008, 08:26 PM | #13 |
"THE GREEN GOBLIN"
Thanks For Your Help Everyone I Can Now Check This Off My List ! Tranny Complete!!!!!!!!!!!!!!!!
Petey-pablo
08-11-2008, 08:27 PM | #14 |
"THE GREEN GOBLIN"
SURE LET ME GET THAT
Petey-pablo
08-11-2008, 08:30 PM | #15 | |
"THE GREEN GOBLIN"
Petey-pablo
08-11-2008, 08:52 PM | #16 |
I Have A Tranny Shop And Have To Keep 2 Types Of Gaskets. Durapreme (hard Paper) And Cork Because Different Builders Use Different Types. I Like The Durapreme Because They Are Rigid And Don't Squeeze Apart Like The Cork When They Get Oil Soaked Or Torqued Too Tight. They Can Also Be Reused If Need Be. Most Tranny Shops Will Sell You One For About 3 Bucks. The Filter Is Loose On The Bolt So It Can Stay Dow In The Bottom Of The Pan Where The Fluid Is.
08-11-2008, 08:56 PM | #17 | |
"THE GREEN GOBLIN"
Petey-pablo
08-11-2008, 09:01 PM | #18 |
i just did the same thing on my th400, and i used the rubber one.also i believe the oring goes on the tube that goes into the filter iirc.
