It'll buff out
Lets see your stereo set up
I am not wanting to spend the money on relocating my gas tank and not sure how i should set up my system.
Im thinking about putting in 2 under the seat subs 2 6x9's in the door and some kick panel speakers but that will take me a while to get the money up for that but right now i have to 6x9's and im thinking about putting them under my seat for right now. Just give me some idea's by posting pictures of your set up. And my last question is will just 2 6x9's be enough sound to go over the engine and road noise? Thanks |
Re: Lets see your stereo set up
I've got two different setups in my trucks, but I can tell you that full range speakers under the seat will not sound very well. Subs might work under the seat but full range speakers will be like wearing ear plugs. I've got a couple nice Alpine 6x9's in the doors on one truck and it is plenty to drown out the motor noisy for me. Everybody will have differnent opinions on what sounds good. I'd say start with the doors and if you need more add them. Also I really love the new head units with usb. No more cd's to burn or go bad.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
I used a pair of those 'under/behind the seat' style sub boxes in my 67 Retro-Rod back when it actually saw day-light. The only mod req'd was I had to remove the seat adjustment linkage under the seat. I didn't ever move the seat & that allowed them to fit so it was a cheap & easy option.
I removed the crappy subs that were in them & swapped in some much better quality mid~upper end subs that req'd very little air space for decent sound. This was much cheaper than relocating the gas tank & adding a big box behind the seat that would take up precious leg room. The doors were already cut for some 4" round speakers so the holes were opened up a little more & received some mid~upper end quality 6x9's for full range sound. I swapped the factory dash speaker for a custom/homemade bracket that held a pair of 4x6's (quality matched to the 6x9's). I had a Kenwood DIN style CD player & a large Kenwood amp that powered it all. The amp mounted to the cab floor between the boxes so you only saw the door speakers. It didn't look like much but sounded nice & out of sight = less temptation IMO. I also never did any sound quality improvements like Dynamat or insulation other than the OE rubber floor mat so that would only have made it better. No pics to offer since this was more than a 'few' years ago . . .....
Old member
I need a newer head unit so I can use a MP3 player with it.
Have a 400 watt amp hooked to the 2 10" subs and 3 ways under the seats. Have a 100 watt to the tweeters & 2 way in the dash. I had the tank removed before I did the speaker's but it didn't loose any leg room. Placed the passenger side tweeter where the clothes hanger was and did the same on drivers side. Built small box under drivers seat for one of two 3 way speakers. The other one just sits under the passenger side seat. Placed two 2 ways in the dash over the radio too.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I lost my photo hosting site and haven't set up a new account to show mine, but I mounted 4" separates in the door panel (NOT the door) of my '70. I mounted the crossovers on the kickpanels. I had a 4-3-2 channel amp bridged mono on the rear to drive a single free air 10 in an infinite baffle (just a box sitting on the carpet with an open back). Sounded GREAT and was completely out of the way. Amp was a Crossfire (great value) and speakers were all Kickers.
Retired Air Force Veteran
![]() Join Date: Aug 2007
Don't have anything yet but I'm gonna keep it simple since it's just a W/E cruiser. A small dash speaker and an amp with an RCA/3.5mm wire to plug my I-POD into. I'll put in a radio delete plate and hide the amp.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 08-12-2008 at 09:59 AM. |
![]() Join Date: Sep 2007
I mounted some Boston 6 1/2" with some of those kick panal mounts they sell on LMC and such but what they dont tell you they dont fit quite perfect, I still have to trim just a little bit and tuck them in the door seal and 2 way tape em so they dont rattle. I also have two 3 1/2 Audio Art speakersin a custom made bracket above the radio. I`m just running an Alpine 2 knobber for now, but I`ll be mounting a din cd player in the glove box later and some low profile subs under the bench seat from an early 90`s chevy truck
1967custom Last edited by michael bustamante; 08-12-2008 at 10:43 AM. |
all i got is a cd deck with aux in and 2 6x9s in boxes at the front of the seat drwons everything out quite nicely
- Josh Im not white trash, I'm one step above that..... more like white clutter |
#9 | |
FarmBoy.
My stereo is far from being impressive. But it's music. So hey.
It was a $100 Sony special from walmart, including stereo/headunit, 2 6's, and 2 6x9's. ![]() The 2 6's are in the stock position. ![]() and I boxed the 2 6x9's, and shoved 'em under the seat. ![]() I had to unbolt the seat, to get the box under it the seat frame rail, but once in, it fit nicely. It's not the greatest, but I have no gripes about it - the music is more than loud and clear enough that I can hear it over the road noise, motor noise, exhaust out the side, and open windows. -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
jvc head, 6.5's in doors, 5X7's in rear cab corners behind seat, i took my 2 12's and 1000 watt amp combo out and put that in my civic so i have 1 12 there now and need an amp cuz the one for that got stolen. sound deadener everywhere, and sounds good. rattles the door lock/handle linkage still, and thats the only problem.
2 6x9's in the doors and a 12 sub under the driver side. Sounds great, you don't need a whole helluva lot to make some sound in these trucks. The trick is to tune everything right and play it loud!
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
It'll buff out
thanks alot guys you gave me some ideas i need to get some under the dash speakers though cause i dont have any but i'll post in my build the pics of what i do later on.
keep posting if you have any differant set ups |
#13 |
Right now I just have a couple 6in in the doors. I am looking to add a sub under the seat and a amp there also. I do like that the original owner left the stock stereo in and placed the new one under the dash.
#14 |
here ya go. Its all I got...
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#16 |
Built 4 Speed
Well if you got the bench and a column shift a Center console made out of mdf could give you many ways to mount a head unit and speakers hide an amp/wires possibly even a small woofer.
my plans ![]() what i got (temporary speaker box) ![]()
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
