08-11-2008, 08:05 PM | #1 |
Ordered Old Air A/C system.
After reading on here about peoples 's problems with vintage air systems fogging up their windows, I started looking into Old Air systems.
So today I called them up to see if they could get me a custom setup since I already have a compressor on the front of my 5.3L. I also have the condensor. So after talking to the sales guy and going through what all I'd need, I just went ahead and ordered it. I got a custom bulkhead fitting that I will probably hide on my shaved firewall. I'm gonna have to come up with a custom mount setup for the under the dash setup, and probably have to order some hard lines once i have it installed. I will probably also have to get a few fittings to connect my newer style compressor with the rest of the system. The guy I talked to on the phone was pretty helpful. I got the setup to install the factory dash outlets too (mine is a non a/c cab) and I'll also be using the factory style A/C controls....though the guy told me it won't operate exactly like factory....no biggie to me. I called them up initially just to see if they could do a custom setup, but ended up just ordering it before I got any of your inputs. So, how do people like thier Old Air setups? Oh, this is the "Hurricane" setup if that matters. |
08-11-2008, 08:10 PM | #2 |
Re: Ordered Old Air A/C system.
We installed the kit from classic auto air on my friends 72 pro touring camaro and it works perfect, so I ordered a kit for my 71 c10 I have not installed it yet as we are doing a motor swap once the new motor is in I will install it and post picts...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 08-11-2008 at 08:23 PM. |
08-12-2008, 08:19 AM | #3 | |
A/C rocks. Let us know how the install goes.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-12-2008, 02:35 PM | #4 |
Green club
Congrats on the purchase, I would so love to install one in my truck
On a side note, that Camaro is wicked
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
08-12-2008, 04:47 PM | #5 |
The fogging issue is a heat mode problem, not an AC problem and it is also a more northern problem. Factory HVAC systems always pull fresh air in heat mode. Using heating and recirculation mode (*some cars can) usually ends up fogging your windshield. Most of the after market full HVAC systems use only recirculated air, no fresh air. There has also been the occasional complaint about not enough heat. The complaints are few and far between because only a few of us will put piles of money in our trucks and then drive them in the salt belt states in 0° weather.
Not going to drive in your ride in the winter? No problem. * Dodge Neons on some years had a separate fresh air/recirculate switch. The manual tell you to NEVER run the heater in recirculate mode or you windows will fog. And it did. Not long after I started working in a Ford HVAC lab, we had a class on Auto type HVAC systems. The same statement was printed in Ford HVAC training manual.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-12-2008, 05:00 PM | #6 |
Product ID: AC0944
Peanut style compressor Block GM / Sanden V7 OEM compressor Discharge Pad - Allows you to adapt to standard #8 female oring fitting Order as AC0944 Price: $9.98 Product ID: AC0945 Peanut style compressor Block GM / Sanden V7 OEM compressor Suction Pad - Allows you to adapt to standard #10 female oring fitting Order as AC0945 Price: $14.98 These are the two adapter fittings if your hose"s mount on the top of the compressor. these i ordered from docs-blocks Last edited by Tom G; 08-12-2008 at 05:02 PM. |
