Old 08-12-2008, 12:02 AM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Rear suspension questions
Hey guys, I recently picked up a disc rear out of a Caddy & it has mounts for a triangulated 4 link cast onto it
My question is, would I be better off building new arms for the rear axle & make mounting points on my frame to use the 4 link
Or, just unbolt the disc brakes & weld on some trailing arm perches on a 73 rear I have ???
I know the 4 link is a lot more work, but would there be any real advantage by using it ???
The truck is bagged & will have a 3" or 4" notch (at least to start with)
the other thing is, if I use the 4 link set up do I need to build the links the same length as what was under the caddy, or can I make them longer ???
Thanks, Matt
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 08-12-2008, 08:36 AM   #2
SCOTI
SCOTI's Avatar
Re: Rear suspension questions
GM's converging 4-link suspensions in stock form were notorious for binding. Aftermarket set-ups utilize different dimensions that possibly eliminate most of it. I know I use the Currie style johnny-joints on the end links of the arms on g-bodys (late model Malibus) to minimize binding.
I would stick w/the truck arm set-up & swap the disc hardware over. My guess would be the truck pumpkin will be stronger than the caddy & the truck arm is a proven performer that's simple & won't require all the extra fab work for unknown gains.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-12-2008, 12:01 PM   #3
SanitysBane
I agree with Scoti, the factory 4-link suspensions on the G-bodies are known for binding up big time. Keep it simple, unbolt the backing plates, but them on your rear end and use the truck arms, they are a proven winner time after time.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 08-12-2008, 01:01 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks guys, lot less work anyway
I dunno bout the caddy rear being weaker tho, this think had a TH-400 & a 500ci
Sinister
Killer
Old 08-12-2008, 02:25 PM   #5
panhandler62
Java Mechanic
panhandler62's Avatar
I'm going to pin my question to the end of this since it's related..
I plan to have a static suspension but am still considering using bags in the back (would use a tire stem type valve, just like old-school air shocks) instead of springs. Is this rational or am I loosing my mind?
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 08-12-2008, 03:14 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thats no problem
I have schrader valves on my truck currently, as I dont have a tank, compressor, or electric valves on it yet
Just make sure you dont have any leaks & you should be good... It would be rather funny having a static drop that had a mind of its own
Sinister
Killer
Old 08-12-2008, 03:17 PM   #7
SCOTI
SCOTI's Avatar
No problem @ all. It's not the most convenient if you adjust the ride height constantly, but it will work fine.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-12-2008, 07:38 PM   #8
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
hey Pan, a great add to your idea is one of those cigarette lighter type small compressors. We used to do it like that back in the day. Used to roll into a show and lay out and then take forever to air back up for the cruise home. Great cheap way. Nice to have in case you're ever spontaneously loading up with weight unexpectedly ( great swap meet find , etc...)and need to add a few pounds
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
