08-12-2008, 02:54 PM | #1 |
Any issues with this motor?
I found a motor/tranny combo for sale in local ads. Its a 350 tbi/ 350 tranny out of an 88 van. Ad says motor was rebuilt last year. Any issues or problems installing this into my blazer? Should I grab anything else out of van (wiring, etc)
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
08-12-2008, 04:20 PM | #2 |
I'm a poor spectator
Re: Any issues with this motor?
It will bolt right in, if you're using the TBI, grab as much of the engine wiring and computer stuff. I don't really know anything about EFI but I would grab as much as possible just in case you need it.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
08-13-2008, 06:47 AM | #3 |
Gotta get the ECU for sure but if you plan on an after market wiring harness, leave the old wires right there, you won't need em.
TBI requires an electric fuel pump, the van will have an in-tank pump. You could do an elec. frame mounted pump and be fine. You'll also need an O2 sensor bung welded into your exhaust system. Great mod IMO, between the serp belt set up and the TBI, your light years ahead. |
08-13-2008, 11:22 AM | #4 |
I believe that motor is a one piece rear main seal. You need to get the flywheel and I think the starter nose is different between the one and two piece seal motors.
08-13-2008, 12:19 PM | #5 |
its probably not a huge horsepower motor i dont really know if it is a 350 tranny
but it would probably be just fine for a daily driver if i remember right it will have some really long and squirly dipsticks (oil,tranny)that come way up to the core support of a van |
08-14-2008, 09:20 PM | #6 |
I'm completely guessing... But wouldn't an 88' van have a 700r4 (2wd) tranny??
08-14-2008, 11:44 PM | #7 |
The ad says turbo 350 but who knows. He says the tranny is a little rough but he's throwing in a spare that "shifts" good.
