08-12-2008, 09:27 PM | #1 |
33's on stock ride?
Can you fit 12.5 x 33's on 71 blazer with stock springs and rims, or maybe 10.5 x33's or do you need a 4" lift?
08-12-2008, 09:36 PM | #2 |
Re: 33's on stock ride?
I ran 33 14.5 MT Baja Belteds on my Jimmy for awhile running 15x8 chrome spokes. The rubbed a little on the front springs when the wheel was cut all the way, and in the rear when the body rolled. You should have no problems with a 12.5 on an 8" wheel with 4.5" B/S, but a 10" rim would be better. Personally, I would consider running a 285 75 16 on an 8" rim with 4.5 B/S with no lift.
08-12-2008, 09:49 PM | #3 |
thanks for the reply, would your suggested tire be a 15's instead of 16's"
mine are 15's i think that size still qualifies for a tire warranty. |
08-12-2008, 10:13 PM | #4 |
i just checked the rim size you were correct. 16's x 8" wide. cool. any one got pics with this tire size combo?
08-13-2008, 06:32 AM | #5 |
Mine stock on 33X12.50X15s. Those are stock rallys off a 1987 Suburban. Same width and offset as any other '73 - '87 4X4 rally (15X8). They have never rubbed anywhere at all. This truck does not get really twisted up off-road, only mild wheeling.
Tim |
08-13-2008, 06:33 AM | #6 |
A 10" rim will stick out further, so it really wouldn't be better for running stock suspension.
Stick to an 8" wide wheel w/4" BS, it's the best all around fit for 33's & stock suspension. Board member BobbyK wheels with that combo quite successfully. |
08-13-2008, 10:21 AM | #7 |
Got Big Block?
Here's my stock suspension '72 on 33x12.50's on 15x8 wheels and they fit fine. However, a 2.5" lift will be going on soon!!!
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 08-13-2008 at 10:24 AM. |
08-13-2008, 10:26 AM | #8 |
not a blazer but here are 33x10.5x15's with stock suspension...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-13-2008, 10:31 AM | #9 | |
Welcome to the board. |
08-13-2008, 12:26 PM | #10 |
here is stock suspension
33/12.5/15 10" wheel rubs some in reverse turn body roll |
08-13-2008, 03:52 PM | #11 |
I have 15x8 wagon wheels with an unknown BS (I'm thinking it's around 3.75") wrapped with 32x11.50 Goodyear MT/Rs. Those do rub at full lock in both directions! The outer lugs on the tires are quite large, so keep that in mind when choosing tires. Just because the sidewall says it is a particular size does not mean it will spec out the same as another brand/style of the same size.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
08-13-2008, 08:22 PM | #12 |
Thanks again for the great photo's. Ok i have decided on the 33's x 12.5 on the 15 x 8 rally's. Heres a sick picture of what it looks like now. I will update with a photo after.
08-13-2008, 08:32 PM | #13 |
Built 4 Speed
http://www.4wheelparts.com/aux_incl/tire_fitment.html
if it helps says your good to a 32.
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" Last edited by d10s69c10; 08-13-2008 at 08:33 PM. |
08-14-2008, 12:14 PM | #14 |
wow blazzin that is a sweet slick mofo
08-14-2008, 10:39 PM | #15 | |
$100- 32x11.5 Pro Comp blems on 15x10's .
His: '71 K5 Blazer Hers: '66 Volvo 122S Theirs: '98 Wilderness Travel Trailer Last edited by pistolpapa; 08-22-2009 at 04:08 PM. Reason: update url |
08-18-2008, 11:36 PM | #16 |
my jimmy had 33's x12.50's x 15's mickey thompson belted radial tires they rubbed turning normaly not wheeling i bouht 32's x 12.50's x 15's bfg mudd terains i had no problems with turning and wheelin the wheel size are 15's x 12's the 33's rubbed the front fenders top and front and back, top on speed bumps front and back by turning. the 32's no problems at all.
08-19-2008, 09:54 AM | #17 |
I'm running 33-15.50 on 10" wheels and no lift. Yea they rub, but I needed to pull a fertilize buggy in wet pasture and that's the only mud tires I had! With no money for tires or lift I just let em rub.
08-20-2008, 10:22 AM | #18 |
i love it it has character
08-27-2008, 09:35 AM | #19 |
Now this looks rigth! had a bit of trouble at the tire shop. Power blew out so they could not get them balanced.After I get them balanced, I will put the rings and caps on. got firestone destinations 33 x12.5. no rubbing on the way home, have not really driven it yet. can't wait.
08-27-2008, 11:27 AM | #20 |
That is a sweet picture. It looks like it was taken a long time ago, like when it was new.
