Fuel Injection on a 305
I have a 84 gmc sierra 305, I am looking into turning my carb set up into a fuel injection. Anybody with info or kit to use? just doing some research on what I need.thanks
Re: Fuel Injection on a 305
A TBI setup from a 305 will work, as will a TPI setup from a car. Good factory setups that can be had for cheap and will run as is with no tuning. The TBI is fairly simple and performs well. The TPI is more complicated but will most likely make more torque. Do some searching on "TBI swap" and "TPI swap"
1977 GMC Sierra Grande |
Buy used GM parts for an '87 TBI, or up to '91 Burb/Blazer/1 ton. The 305 throttle body is different than the 350. You will need an adaptor plate at the intake, or a FI intake (availble dirt cheap) with the matching heads (center 4 intake bolts are re-angled). Or go aftermarket. use an inline fuel pump.
Tuned port, easiest to swap complete motor, need a lot higher fuel pressure and more wiring.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
BAD BOW-Silverado XST
So you want fuel injection?
Check out these additions: http://www.hotrodlane.cc/PROJECTS/projectsindex.html#ls |
#5 | |
TBI system requires 12 to 15 PSI to be happy while TPI needs 45PSI. High pressure fuel system require planning and careful fabrication. Successful, low cost FI swap needs a complete donor vehicle, otherwise piecing it all together takes time, effort and naturally money. But rewards are many! //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
guys thanks for the info...will help me out alot thanks.
TPI is the best FI for a 305. Other FI system work better on larger bore engines.
