Old 08-13-2008, 12:22 PM   #1
Chevyholic
Will it run today?
Chevyholic's Avatar
Truck Won't Start
Hey guys, need some troubleshooting tips. Jumped in the truck this morning and the truck wouldn't turn over. And by not turning over, I mean wouldn't even click, so the starter doesn't even sound like it is getting power. I replaced the battery because I needed a new one anyway, but same thing.
Things to note. Starter is about a 1.5 years old and I'm running a remote solenoid. All connections are clean and tight. What else should I be looking at?
Thanks!
David
Jaws, the 1971 Chevy Cheyenne Longbed.
She's big, grey, and has an insatiable appetite!
Chevyholic is offline   Reply With Quote
Old 08-13-2008, 12:26 PM   #2
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Re: Truck Won't Start
Have you tried Bypassing the solenoid to make sure it’s not bad? I just went through this with my neighbor’s truck and found out the solenoid was the problem. Careful this may bugger up the threads on your lugs and make it a pain to get the nuts off.
Edit* And 1.5 years for a starter doesn't matter. When I did alternators starters and batteries for a shop years ago we would do quite a few "lifetime" starters that people changed out 3 in 6 months then finally came to us. And sometimes ours would fail also. Starters and batteries are a pain. My Brother gets 6 years with a Stock motor craft. I get 1 year with an optima.
Personally I have a gear reduction in my truck now and love it. But pricey at $250.00
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 08-13-2008, 12:29 PM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
How about your ignition switch? Try jumpering from the unfused hot feed in the panel to the starter feed on the switch. That will tell you if your problem is there or somewhere downstream.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 08-13-2008, 12:33 PM   #4
Chevyholic
Will it run today?
Chevyholic's Avatar
Originally Posted by So.Cal.Super View Post
Have you tried Bypassing the solenoid to make sure its not bad? I just went through this with my neighbors truck and found out the solenoid was the problem. Carefull this may bugger up the threads on your lugs and make it a pain to get the nuts off.
This might be it. I just ran out and jumped across the solenoid with a screwdriver and it tried to turn over...once. Tried again and nothing. Will try bypassing it and see what happens.
Old 08-13-2008, 12:38 PM   #5
Longhorn321
Size Matters
Longhorn321's Avatar
Do you have a volt meter or at least a test light? Jumping the solenoid/switch and replacing parts are good quick things to try but if that leads nowhere, you need a good systematic approach. Try to find out where the power/ground is breaking down. Remember, the problem could just as easily be on the ground side as it could the power side. Did you check the grounds from the engine to chassis/neg. side of the battery?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 08-13-2008, 12:47 PM   #6
So.Cal.Super
It'll Buff Out!
Very true. Volt meter will give you the best and grounds are just as important as power.
Check all the connections for broken terminals. I had one that had me banging my head for hours. Found out the terminal had split but because the wire was so stiff it held it in place like it looked ok until you moved it.
Man Card Rules
Old 08-13-2008, 12:47 PM   #7
420am
420am's Avatar
Check the neutral safety switch. Shift all the way through the gears a couple of times and try it again. My truck does that sometimes. It goes into park and doesn't quite know that it's in park and won't start. Lights don't dim, no click.. nadda.
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 08-13-2008, 12:55 PM   #8
Chevyholic
Will it run today?
Chevyholic's Avatar
Yes, I have both and will run through the electrical side from ignition to starter to see where I'm buggering. The entire electrical needs replacing, but will have to wait until the temperatures get down to the point I can stand to be outside for longer than 10 minutes.
Thanks for all the help!
David
Old 08-13-2008, 01:12 PM   #9
lks dcvn
lks dcvn's Avatar
with 420am - had a similar problem...give that a shot - or find neutral and then try it again.
lks dcvn is offline   Reply With Quote
Old 08-13-2008, 04:02 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there is no need to jump the solenoid now, you already did, and you now know the starter, battery, and all heavy guage battery cables are working. You know the ground is good too.
Now, you need to find out why the purple wire that goes from the ignition switch, to the neutral safety switch (if it's an automatic) and then to the solenoid isn't getting power when you turn the key.
Old 08-13-2008, 04:37 PM   #11
Longhorn321
Size Matters
He said that when he tried jumping it the second time he got nothing.
...WOOOO HOOOO!!!!
Old 08-13-2008, 04:57 PM   #12
Chevyholic
Will it run today?
Chevyholic's Avatar
True, and checked with the meter that I'm getting 12v to the line in on the solenoid, but there is nothing when jumping across, so I'm thinking the solenoid is fried.
Even eliminating the ignition, I should get something when jumping across the solenoid, right? This is the first time I've used the remote solenoid, so I'm not sure how long those should last, but I've only had this one about a year and a half.
Old 08-13-2008, 05:03 PM   #13
Longhorn Man
I bet if he tried again it'd work.
Very common to not get a good enough contact. Anyone who has done it a lot should know.
What kind of tool are you jumping it with?
Old 08-13-2008, 05:13 PM   #14
Longhorn321
Size Matters
When you say 12V on the line in...are you referring to the one from the battery or the one from the ignition switch (purple wire)?
It shouldn't matter if the solenoid is fried if you are jumping the two big wires.
...WOOOO HOOOO!!!!
Old 08-13-2008, 05:34 PM   #15
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a diagram of a common remote solenoid hook-up. Remember that the original starter solenoid has to be in the circuit and in working order to engage the contacts inside the solenoid that feeds the starter motor. The S terminal on it must get a full 12 volts for this to happen so it may be a bad connection there or the starter solenoid may be bad. If you run a jumper wire to the S terminal on the starter solenoid from a hot post from the battery the solenoid should at least click. The I terminal on the remote solenoid in the diagram would need to be grounded in order for this type solenoid to work.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-13-2008, 05:56 PM   #16
420am
420am's Avatar
Did you try the neutral safety switch?
Not trying to harp on about it.. just hoping that's all it is.
