Old 08-13-2008, 12:35 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Question Replacing rear main seal with motor in truck...
Tried a search with no luck. Rear main seal is starting to leak a bit. What's involved with changing it with the motor in the truck? Will it be possible to change out the oil pump at the same time? I don't have a place to work on it as we just got our driveway repaved; so I'm looking for a place to have it done, but I'd like to have an idea of what's involved.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-13-2008, 12:49 PM   #2
Garagedude
Garagedude's Avatar
Re: Replacing rear main seal with motor in truck...
What size motor do you have, my guess is that you most likely have a two piece rear main seal. You will have to drop the oil pan, which can be a pain when the motor is in the truck, most likely you will have to jack the motor up to get the pan out. You will need a torque wrench to torque the rear main cap back down after replacing the seal. The oil pump will be easy to replace with the pan off.
Garagedude is offline   Reply With Quote
Old 08-13-2008, 12:55 PM   #3
SoCal71K20
Yep. Once you drop the oil pan, seal and oil pump are accessable. With rear bearing cap removed, you can carefully rotate remaining rear seal half out. Make sure you you use sealant in right places and installation is reverse of teardown.Use proper torque on bearing cap. Good luck.
SoCal71K20 is offline   Reply With Quote
Old 08-13-2008, 12:57 PM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
nice to see ya back, Sin. haven't seen you in a while.....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 08-13-2008, 01:05 PM   #5
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Nice fresh new smooth driveway. Who could ask for a better place? I'd rather spill some oil first then have a friend stop by in a clunker and let it drool all over.
On the other hand my wife would probably back over me in my truck while screaming and yelling about how we just had the driveway done. So I understand.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 08-13-2008, 02:59 PM   #6
Ackattack
Ackattack's Avatar
Yep, definatly doable.
I'd suggest getting a 1 piece oil pan gasket for when you put the pan back on. It will save you a lot of time and hassle.
Ackattack is offline   Reply With Quote
Old 08-13-2008, 03:12 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
Thanks for all the replies. Nice to be back, been working a lot. 350 with 2 piece rear main seal, started to leak on our brand new concrete driveway. Luckily the driveways sealed and I had some cardboard down, or I'd be a dead man. I'm not going to be doing this myself, just don't have the time or place to work on it, sounds like it's gonna cost an arm and a leg.
Beat it to fit,
Old 08-13-2008, 08:57 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
Where would I be putting the sealant, and what kind? I found a garage down the street, but I think I may be lending a hand to make sure it gets done right.
Any other details you guys have would be a big help.
Beat it to fit,
