Old 08-13-2008, 12:38 PM   #1
pat123
Pat
pat123's Avatar
what size cage bolt do i use on my box?
is it 7/16?
pat123 is offline   Reply With Quote
Old 08-13-2008, 03:58 PM   #2
66skylarkpost
66skylarkpost's Avatar
Re: what size cage bolt do i use on my box?
you mean carriage bolts ? u can use 7/16 yet you may have to address the holes in the frame and they cost more . 3/8 are typicaly used
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 08-13-2008, 06:09 PM   #3
pat123
Pat
pat123's Avatar
whats stock?
Old 08-13-2008, 07:16 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Which carriage bolts are you referring to?
The bed to chassis mounting bolts or the ones that mount the sides, inner fenders and front panel to the bed?
68gmsee is offline   Reply With Quote
Old 08-13-2008, 07:58 PM   #5
pat123
Pat
pat123's Avatar
the bed ones
well both would be good to know
Old 08-13-2008, 09:28 PM   #6
68gmsee
Active Member
68gmsee's Avatar
On my GMC fleetside the bed bolts are 3/8th by 4" long. The short carriage bolts are 1/2" by 5/16th.
I wasn't able to find the 1/2 inch length carriage bolts in local hardware stores. The shortest they carry here is 1 inch.
