08-13-2008, 01:32 PM | #1 |
New Wiring Harness
Does anyone have any recommendations on the best place to get a new wiring harness from for my '65? The wiring in my truck is so dilapitated that I'm just going to replace the whole of it.
My 1965 GMC 4x4 http://67-72chevytrucks.com/vboard/s...22#post2754022 My brother's 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 Last edited by Calitruckgrl1; 08-13-2008 at 01:50 PM. |
08-13-2008, 02:26 PM | #2 |
Council of the Elders
Re: New Wiring Harness
American Autowire's Classic Update kit worked well for me. It gives many extra circuits for power upgrades like AC, power locks, etc. Pretty easy to install...good instructions.... did it myself and I am no electrical expert. Rating= A to A+.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
08-13-2008, 02:30 PM | #3 |
I used a Painless Wiring harness in my street rod. Went in real easy. I'm currently doing a frame off Restro-rod on a '64 GMC SWB, on it I'm planning on using a harness from American Autowire. Comes with all switches and grommet's, but it's pricey.
Good Luck |
08-13-2008, 04:19 PM | #4 |
Keepin it old school
Good timing on this thread I need the same info and opinions on what harness to use..
08-13-2008, 05:02 PM | #5 |
65 - Chevy C10
If you want to go with "original" type wiring harnesses check out M&H Wire Harness Company. M&H Website Link
I did for most of my harness components. Looking back i should have just went with aftermarket kit. But M&H would definately be an easier install if thats what your looking for. |
08-13-2008, 05:21 PM | #6 |
I used an E-Z wiring harness. It was about $165, for the price its a decent product. Some don't like it because its cheap, I installed mine 3 years ago and I thinks its a good product.
08-13-2008, 05:34 PM | #7 |
If you want the original harnesses go through the Truck and Car Shop.... Heres the online catalog and the harnesses are on pages 104-106
http://www.truckandcarshop.com/truck...t60_cover.html |
08-13-2008, 06:25 PM | #8 |
For factory fit wiring harnesses, try:
www.classicparts.com www.lmctruck.com www.bowtiebits.com www.oldchevytrucks.com I prefer factory equipment, so I chose to go this route instead of the many aftermarket harnesses available. |
08-13-2008, 08:58 PM | #9 |
you got any links for the E-Z one?
CHEVY ONLY |
08-13-2008, 09:10 PM | #10 |
Another vote for the American Auto Wire Classic Series kit. Very easy to understand - I had never wired a vehicle before and it went very smooth - two years of driving and no problems related to the wiring kit.
08-13-2008, 09:55 PM | #11 |
I was thinking about using the Summit harness. It is not a direct fit and will take some doing to install. http://store.summitracing.com/partde...art=SUM-890021 $229 for the 18 circut harness. I am still up in the air about it though.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
08-13-2008, 09:57 PM | #12 |
65 - Chevy C10
Adam / Tony,
Pretty sure the factory fit harnesses all come from M&H. The good thing for us So Cal folks is that its local. Ive seen the truck shop ones and there is an M&H card in the baggy. |
08-13-2008, 10:57 PM | #13 |
KOFFIN DRAGGER
I also used an ez harness, I like it, seems to be pretty good quality and everything is well marked. Thier customer service leave alot to be desired, but a good harness.
If the life I live dont kill me, then I guess I'll never die! New updated stuff at www.kdrodworks.com My site still needs help, web guys and gals pm me. the best guys in the whole world: sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231 |
08-13-2008, 11:19 PM | #14 |
I went with a painless harness from summit. I actually liked the fact that it wasn't direct fit. It allowed me to route some of the more visible wires the way I wanted too...hidden and out of the way. The harness is good qualiity, well labeled, and the instruction made sense for the most part. Horn relay is on the fuse block. Comes with a bunch of extra stuff like thick ga. wire and a 50amp maxi fuse for one wire alt. (I put the fuse on the main feed line to protect the whole harness). You can also pull it out along with the coil fuse for security purposes. Even comes with a connector for late model steering columns. Comes with a bunch of extra fuses and connectors too. as all the gromets you need (since it does away with firewall connectors).
I also used painless's wire loom (powerbraid I think?). Cool stuff. |
08-14-2008, 07:25 AM | #15 |
Here it is Joe. http://www.ezwiring.com/wiring_harness.html
08-14-2008, 08:59 AM | #16 |
I am planning on using the EZ one also. I found them on E-Bay.
http://cgi.ebay.com/ebaymotors/UNIVE...mZ310074514820
"We the willing led by the unknowing, are doing the impossible for the ungrateful. We have done so much for so long with so little, we are now qualified to do anything with nothing." |
