Old 08-13-2008, 02:38 PM   #1
FormerMember
Filling Rockers to prevent rust
So we replaced the rockers on two vehicles. What are you doing to help prevent them from rusting?
FormerMember is offline   Reply With Quote
Old 08-13-2008, 02:42 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Filling Rockers to prevent rust
Took a garden sprayer and soaked the inside with POR 15, . I'm not sure what else you can do.....
Hart_Rod is offline   Reply With Quote
Old 08-13-2008, 02:48 PM   #3
raggedjim
raggedjim's Avatar
You can bet the garden sprayer will never rust!
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 08-13-2008, 03:36 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I did mine about 15 years ago and painted the inside with rustoleum. Haven't had any problems. But, then again I'm not in rust belt.
I suppose POR15 or similar would help keep the rust down. I have a friend that fillled a cavity in one of his Mustangs that he was restoring with spray foam? I never asked him if he's had any rust problems.
68gmsee is offline   Reply With Quote
Old 08-13-2008, 03:38 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
Bad idea, holds moisture/blocks drainage/won't allow water to get out.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-13-2008, 04:12 PM   #6
68gmsee
Active Member
68gmsee's Avatar
That's what I thought.
Old 08-13-2008, 04:25 PM   #7
W. Higgins
W. Higgins's Avatar
Don't drive it in the salt, or allow trash to get in there. That will go further than anything.
It's not the most durable stuff, but you can spray the inside with weld-through primer before installing and still have no trouble welding. They vary in quality, but I think U-Pol makes a good one.
W. Higgins is offline   Reply With Quote
Old 08-13-2008, 04:26 PM   #8
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Mine rusted off havent had a problem with them since!
But yes por 15/rubberized undercoating/spray paint. are all good choices. in that order.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 08-13-2008, 04:50 PM   #9
67dragtruck
67dragtruck's Avatar
I always thought it would be a good idea to replace the outer rocker and leave the inside piece off so that there was nothing there to hold dirt etc. I really don't see the point in that piece.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 08-13-2008, 05:06 PM   #10
67ChevyRedneck
Tom
That's what the two cab supports bolt to, and being perpendicular to the floor of the truck, it has a lot of structural strength
Jesse James
Project "On a Dime"
Old 08-13-2008, 05:13 PM   #11
bad6772
Official Site Guitar Shredder
bad6772's Avatar
I disagree..tom....That (piece) inner rocker basically makes the Outer rocker strong and is a significant part of the cabs structure for the floor supports and just more strength....If it was not ..it would not be there........The best thing i can say to use is........BODY WAX..(also slang for Bees Wax)......you can get it at almost ANY automotive paint and supply company.....Its a wax that not only repels moisture. but does not let the moisture penetrate the metal.....It comes with a wand that has holes in it to give you a 360 spraying surface... also it can reach areas that most others wont because of the sheer small size of the tube......3m makes a good body wax as does Wurth or Kent........................
bad6772 is offline   Reply With Quote
Old 08-13-2008, 08:43 PM   #12
Bob D
Rolled on Paint Club
Bob D's Avatar
I think Ford is filling truck A pillars with foam and calling it sound deadener. My truck is finished and painted with Zerorust under and inside the rockers. I am considering filling them with something like this:
http://www.grainger.com/Grainger/items/4KK25
I may first do a trial on my dailydriver Chevy Tracker.
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 08-13-2008, 08:55 PM   #13
Rokcrln
Rokcrln's Avatar
Yes some company's do use a type of foam but it will breath and they use it in the vertical areas not the bottom flat portion of the car. I like Por 15 and Body Way for a prevention but I also pre coat the parts with a good rust paint before they go together. The other important part is to make sure the drain holes are free and that you put the plastic cap/plug back in the front of the rocker to prevent the dirt from filling it up from the front tire spray.
Also keep in mind that nothing is perfect but if you do anything mentioned in this thread (except foam) you will increase the life of the rocker and any other part you install. Remember the factory did a very poor job of rust prevention so anything will help.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 08-13-2008, 09:11 PM   #14
CG
BlahBlahBlah
You would think with all the new crazy bonding agents out there you could put on a plastic rocker and just glue it. No rust.
Old 08-13-2008, 09:35 PM   #15
Shane
Shane's Avatar
I cut about a half inch off the bottom of the backing plates so the water can drain out ...
Shane is offline   Reply With Quote
Old 08-13-2008, 09:43 PM   #16
d10s69c10
Built 4 Speed
d10s69c10's Avatar
THESE AINT NO SATURNS! not a horrible idea tho..*ponders*
496/T-56 in worx.
Old 08-13-2008, 09:52 PM   #17
tcb-1
Nothing to see here.....
tcb-1's Avatar
pray.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 08-13-2008, 10:14 PM   #18
sameyrasmea72
sameyrasmea72's Avatar
The best way I can think is every time you wash you truck, take the time and take a hose and before, during, or after the wash and spray out the drain holes til it is clear. Getting wet is no problem at all, It is staying wet.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 08-13-2008, 11:13 PM   #19
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
My bodyman also suggested a spray wax. I coated everything after finishing my truck... cowl, inside the inner walls of the cab, cab supports, rockers, inside the doors... You get the idea. Make sure you apply it after painting. This stuff will coat the surface it is sprayed on and won't wash off very easily. I sprayed the heck out of everything, laid cardboard down and let the excess drip out.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 08-14-2008, 06:35 AM   #20
Rokcrln
Rokcrln's Avatar
Also make sure your drip rails are sealed right and the kick panels are free of any blockage or dirt.
Kevin
LFD Inc.
Old 08-14-2008, 08:53 AM   #21
I believe drain holes are your best bet in the rust belt.Crap will definately get in,you need to get it back out.Keeping out of salt is obvious,but there`s more.Running in the rain lets grit spray up into crevases and it lays there.We have enogh moisture in the air and condensation from the varying temperatures that will cause rust on a vehicle that`s never seen salt.
Weld-through primer is the first step,then coating after assembly,and finally allowing drainage.That`s what GM did to truck fenders and bedsides in`78 and it helped in a big way.
Old 08-14-2008, 06:08 PM   #22
mbgmike
Kevin
LFD Inc.
All the big three use the foam, the Dow brand name Betamate and Betaseal and a few other names in differant formulas specific to their requests. Dow chemical supplies 97% of the market to OEM's Its used for sound proofing only not for rust proofing. The metal is already treated before its placed inside. Kevin is correct on the upper panels as this is wear they want to control the acoustics. Its one the reason cars are so quiet now. Its used in foreign cars also. We just pain them andundercoat them with a achultz gun.
mbgmike is offline   Reply With Quote
Old 08-14-2008, 06:59 PM   #23
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I use a cold galvanize spray before install
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 08-14-2008, 11:34 PM   #24
matthufham
i'm the one and only guy that didnt replace the inner rockers when fixing my rusty cab on my daily driver. and 3 years later, no problem with flex or any bondo cracking, or any problems. there's nowater/trash inside the rockers because there's nowhere for that to collect. where the cab supports reach the inner rockers, i cut larger drain holes there, and so much sand came out... anyways it seems i'm the only one doing it this way cuz it's half assed
matthufham is offline   Reply With Quote
Old 08-15-2008, 09:37 AM   #25
raggedjim
raggedjim's Avatar
You aren't the only one, I've seen a few trucks done that way, but never tracked them over time. Heck, I've seen trucks run for years with no outer rocker on them...
You are right about the cab support. When I replaced mine they were full of real fine silty sand.
Rg
Roger
'70 GMC Jimmy 2wd
