Old 08-13-2008, 03:44 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Quadrajet question. NEED answer asap....
Anyone know the size of the fuel line nut that goes into the side of the carburetor???? Im thinking its 1/2 or 3/8.
Im doing a fuel line from my mechanical pump to the carb, and i dont know the size on the carb. Carb is not here and just want to get this stuff here so i can just bolt the carb on and attach lines when it shows up....
lyrikz is offline   Reply With Quote
Old 08-13-2008, 03:53 PM   #2
66skylarkpost
66skylarkpost's Avatar
Re: Quadrajet question. NEED answer asap....
the fuel line is 3/8 yet the retaining nut is 5/8 . the filter housing takes a 1 inch wrench , be sure to hold it solid when you loosen the fuel line to avoid twisting the line and its best to have a 5/8 flare or line wrench not to round it off , then its vise grip time . lol
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 08-13-2008, 04:05 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Unless you're in a hurry, I might suggest waiting until you have the carb in hand and do the flairing and fitting then.
However, if you do have a need to do it now, I have a 1977 quadrajet in my garage with the filter and fuel inlet fitting in it. The inside diameter of the female opening where the line from the fuel pump would attach is 1/2 inch.
My assumption is that all quadrajets are the same size, but I may be wrong. You could get an adapter if you make one and it doesn't match.
Sorry... that's wrong. The 1/2" inside diameter is for the male fitting that goes into the female filter retainer on the side of the carb... Mine just had a short male plug in it.
68gmsee is offline   Reply With Quote
Old 08-13-2008, 04:09 PM   #4
d10s69c10
Built 4 Speed
d10s69c10's Avatar
^ agrees^
Oh when you get to that filter, Your going to want to remove it along with the spring and throw it into your neighbors back yard.
get a inline fuel filter.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 08-13-2008, 04:15 PM   #5
lyrikz
PITbut
lyrikz's Avatar
Ok, so the nut that is on the end of the fuel line that screws into the carb. is 5/8's??? And the fuel line itself is 3/8ths??
Originally Posted by d10s69c10 View Post
^ agrees^
Ya, under that big nut is a baby filter... I replaced that already, or am having that done.. I just need to know what size that nut is thats on the end of the fuel line that screws into the carb to keep the line in place.....
thanks for the quick responses.
Old 08-13-2008, 04:20 PM   #6
d10s69c10
Built 4 Speed
d10s69c10's Avatar
its 5/8s i just went out and checked it personally.
the fuel line i could only assume is 3/8 inside diameter. dont got a tape on me but my eye dont usually lie.
496/T-56 in worx.
Old 08-13-2008, 04:23 PM   #7
lyrikz
PITbut
lyrikz's Avatar
ok, line is 3/8ths, the fittion on the end of the line is 5/8ths that screws into the carb.
AWESOME....
Old 08-13-2008, 04:36 PM   #8
lyrikz
PITbut
lyrikz's Avatar
So the wrench is 5/8s????? I told the guy at the store 5/8ths and he said no way.....
Old 08-13-2008, 04:50 PM   #9
lyrikz
PITbut
lyrikz's Avatar
THat retaining nut is 5/8ths, but what size are those threads???? I guess thats what he is wanting to know.
