Old 11-14-2002, 06:42 PM   #1
Project1970
14.1 @ 96MPH
Project1970's Avatar
Possible to have 4 low beams on GMC?
Just a thought I've been kicking around for a while...does anyone make a headlight that would fit in my '70 GMC in place of the highbeams and be a combined low/high beam unit?
I know it'd involve some rewiring...but I think the extra low-beam light would be nice...basically, just have it so all four are on low normally, and then when I click the high beams on, the two go to high.
Hmm...or why not just replace all four and have all four go from low to high...
Hehe...all just thoughts, but I'd really like to know, since a LOT of my driving is at night.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 11-14-2002, 06:48 PM   #2
ckhd
ckhd's Avatar
I think it would be a matter of two new bulbs and a little rewiring.
I set up my friend's '92 K3500 to have both bulbs on with the High beams. Simple matter of a bit of wire and a relay for him.
What you're talking about should be fairly easy, as long as the bulbs fit the buckets (I don't think they are different).
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 11-14-2002, 06:51 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Externial lamp dimentions are the same.
Just replace the plug pigtail and wire to the other light.
I got a ticket for doing this on my 68 Cougar when i was a teen. (first ticket too) They said it was illegal to have that many headlamps on in the low beam selection. Luckily it was just a fix it ticket.
Old 11-14-2002, 06:54 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Longhornmail is right, unless the law has been recently changed. It's illegal to have more than one bulb on each side burning on dim.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-14-2002, 07:03 PM   #5
ckhd
ckhd's Avatar
What about this? I'm no lawyer, but the way I interpret this is that two is the minimum only. Not two and only two.
headlights
If you call them "driving lamps", this one is your loophole if there is a problem.
driving_lamps
I guess if you get a "fix it" ticket, then let's look at the law they refer to and fight it if we don't think it applies.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 11-14-2002, 07:08 PM   #6
Longhorn Man
There are laws that describe a fog light, a driving light, and a headlight. This is why somw of the KC Daylighters are illegal for on road use, even though they are not as bright as a headlight. (some models...not all)
If you want more light, get halligons, and wire them up with a relay getting full system voltage to the lights. It'll be 100% better. much like a newer vehicle.
Old 11-14-2002, 07:28 PM   #7
crazy longhorn
Fabricate till you "puke"
4 headlites?, the Chevs only have 2 ......& they are so brite , they have to wear ...... !
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-14-2002, 07:30 PM   #8
ckhd
ckhd's Avatar
I say do it anyway and fight it if you have to. All they will do is give you a repair order, and investigation into the referenced statute may show that they are full of bull.
If I had a GMC (or anything with four headlights), I'd go do it tonight, just to see what the cops would do and if they would write me a bullcrap hassle ticket that I could fight and get a cease and dissist order with.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 11-15-2002, 12:15 AM   #9
Longhorn Man
It is a fed thing, don't you think they would have done it years ago from the assembly line?
