Old 08-13-2008, 06:16 PM   #1
solidaxel
solidaxel's Avatar
?? GM Column mount 53
Does anybody have a photo of the mount on a GM column with a column shift. Do I need to trim the collar back a bit? This is on my 53 3 window
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-13-2008, 06:29 PM   #2
mbgmike
Re: ?? GM Column mount 53
Not sure what you are needing but here is a stock one on a 51
mbgmike is offline   Reply With Quote
Old 08-13-2008, 06:42 PM   #3
solidaxel
solidaxel's Avatar
Thanks Bigmike,
I guess I forgot to mention that it is a late model chevy van column. I was trying to make this simple without adding a lot of braces and use the four mounting bungs on the column.
LS 3 4L70E
Old 08-13-2008, 06:57 PM   #4
mbgmike
I figured you were speaking of a late model column but was not sure I don't know of anyone making one but they probably have.
Old 08-13-2008, 08:10 PM   #5
54 jimmy
54 jimmy's Avatar
if you want to use a column that fits the stock column mount you could try one from a 68 chevy truck. that is what i am using in my 54 gmc but mine is a stick shift column since my truck is going to have a floor shift. the length is a really nice fit too. sorry don't have any pics for u though.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 08-13-2008, 09:25 PM   #6
orgalmeister
On my old '47 panel, I used a van column. I modified a 2" muffler clamp to hold the column and that tied in with the S-10 brake pedal assembly.
I'll look for pics when get a chance... swamped at work!
'56 truck (the never ending project)
'06 Z/71 loaded (daily driver)
'07 Mercedes-Benz C-Class (wife's driver)
Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod,
orgalmeister is offline   Reply With Quote
Old 08-13-2008, 09:55 PM   #7
solidaxel
solidaxel's Avatar
Thanks guys, still looking for info !!
LS 3 4L70E
Old 08-13-2008, 11:01 PM   #8
cajundragger
I used an exhaust clamp at the top and a floor mount ball and socket on the firewall.
cajundragger is offline   Reply With Quote
Old 08-15-2008, 11:49 AM   #9
Atomsplitter
Atomsplitter's Avatar
This type of GM column?
Atomsplitter is offline   Reply With Quote
Old 08-15-2008, 12:33 PM   #10
Daniel U
Daniel U's Avatar
Here's a few shots of mine.
This is a shot without the lower collar and the holes are for the LED gear indicator lights.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 08-17-2008, 07:48 PM   #11
solidaxel
solidaxel's Avatar
Thanks guys that helps !
LS 3 4L70E
Old 08-24-2008, 11:47 AM   #12
54 jimmy
54 jimmy's Avatar
here's a pic of mine it's a 68 chevy column using the orignal 54 gmc column mount.
Old 08-24-2008, 08:15 PM   #13
weldvair@embarqmail.
GM van column
weldvair@embarqmail. is offline   Reply With Quote
Old 08-24-2008, 09:06 PM   #14
solidaxel
solidaxel's Avatar
Originally Posted by weldvair@embarqmail. View Post
GM van column
So is the hand shifter on the left side, that is one way to clear the brake pedle!!
LS 3 4L70E
Old 08-24-2008, 09:09 PM   #15
Yes
