Old 08-13-2008, 07:56 PM   #1
texastrendz
trans cooler lines for 350 turbo
hey fellas, do the lines on a 350 turbo on a 72 just float to the radiator or are they hung from something, just replaced mine and cannot see if they hang off a bracket or if they just float, any help guys, thanks.
texastrendz is offline   Reply With Quote
Old 08-13-2008, 08:02 PM   #2
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: trans cooler lines for 350 turbo
Mine just run from the transmission, and screw into the rad. They don't mount to anything if that's what you mean.
Then again, my engine/trans isn't original.
texanidiot25 is offline   Reply With Quote
Old 08-13-2008, 08:20 PM   #3
JimKshortstep4x4
There should be a clip for the lines. It attaches to the engine using a stud on the oil pan.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-13-2008, 08:53 PM   #4
texastrendz
just went outside and looked under, i now see the clip you are talking about. looks like i gotta take them loose again and hangem. thanks again.
Old 08-13-2008, 08:55 PM   #5
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Just a thought but you can buy a new aluminum radiator out of a 85 c/10 and it has thee cooler inside the radiator.. if your looking for somthing different. i did it but i got a manual and i just got the thing plugged off.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
