in line 6 Question
Anyone know if a 250, or 292 head will fit on a 235? I've heard they will, but I want to be sure. Thanks
A sweet 2000 Deville..... |
Re: in line 6 Question
i really dont think they will interchange
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
I know a 292 will not work. A 292 is huge.
"Anyone know if a 250, or 292 head will fit on a 235? "
Don't think so. Completely different designs. |
no
absolutely not!!!!! no way. although the 292 and the 250/230 all share the same head
Don't know if this has been posted before, but I found a neat site for inline engine's. Unfortunately, the site does not have a lot of specifics, but it is pretty neat to see some heavily modified inlines. The site is http://www.inliners.org/. Check it out.
but some of the 261 inline sixes I believe do share some parts
Gene Sharp |
Will a 230/250/292 fit in my '55 2nd without a lot of mods? It started out with an inline 6 but it's long gone. I'm considering safety upgrades (power steering, power disc brakes) but want to keep the straight axle and would really like to have a straight 6, even if it's not the right vintage.
Cantankerous Geezer
Nothing interchanges between the 235 and the 250. The 194/230/250/292 series was a totally new design using standards from the small block V8. You can take two V8 heads, cut them and weld them together to make a cross-flow head for the newer six, but you also have to drill new head bolt holes. The valve-train is from the big block.
As for dropping a 250 in an older truck, it is relatively easy. The block is narrower, so different mounts and perches are need. For those contact Tom Langdon at www.stoveboltengineco.com
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Thanks, Fred, I appreciate the info. I've ordered the inline 6 performance book and have a few engines to choose from since most folks have discarded 'em in favor of V-8's. I have access to 700R4 and 2004R trannies, just need to pick one.
I was so close to doing a turbo'd and injected 292 with a muncie 4 speed in my truck. went a different direction though.
putting a 4.2L trailblazer 6 in my Dads 56 though. |
#13 | |
Cantankerous Geezer
#14 |
good luck on trying to find any info a 4.2 swap. I would be very interested in how the 4,2 swap works. I couldn't find any info at all, Ended up selling my 4.2 for $350
