Old 08-14-2008, 12:08 AM   #1
70jnktrk
70jnktrk's Avatar
Caliper lube
Where exactly am I supposed to put the lube on my new disc brake pads. Where the pads contacts the caliper pins?...I have read something about the "back side" of the pads?...thanks
70jnktrk is offline   Reply With Quote
Old 08-14-2008, 12:36 AM   #2
dragginass
dragginass's Avatar
Re: Caliper lube
On the ends of the pads where the pads rub the hardware and on the backing plates of both the inner and outter pads. Pretty much anywhere the pad touches something aside from the composite material.
1971 Chevy C10 LWB Shop Truck
1984 Chevy C30 Dually LWB Tow Pig
1985 Chevy K5 Blazer
dragginass is offline   Reply With Quote
Old 08-14-2008, 09:31 AM   #3
111stony
Re: Caliper lube
The lube goes on the rubber O rings inside the holes where the pins goes through the caliper. It allows the caliper to slide on the pins freely.
111stony is offline   Reply With Quote
Old 08-14-2008, 11:52 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Caliper lube
Please do NOT put any lube on the pads ANYWHERE!!!
They make anti squeak compound for the back side of the pads (metal part) but the lube is for the o-ring/pins to allow the caliper to slide freely.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-14-2008, 11:58 AM   #5
dragginass
dragginass's Avatar
Re: Caliper lube
I apologize I meant lithium grease. I use it all day long at work. It is required to be used at all brake shops.
Old 08-14-2008, 12:49 PM   #6
70jnktrk
70jnktrk's Avatar
Re: Caliper lube
OK...I think I am getting it...anti squeel on the back sides, if necessary?, and lith pad lube grease where the pads slide on cal pins...obviously keeping the contact sides to the rotor clean...thanks
Old 08-15-2008, 11:26 AM   #7
69_C10
Doing it my damn self.....
69_C10's Avatar
Re: Caliper lube
You got it now 70jnktrk!!
69_C10 is offline   Reply With Quote
