Old 08-14-2008, 06:22 AM   #1
SLVESSELS
Turn Signals Problem
My Turn Signals Work When The Headlight Are Off But When I Cut The Headlights On They Stop Working And My Brake Lights Are Working Properly.
SLVESSELS is offline   Reply With Quote
Old 08-14-2008, 07:39 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Turn Signals Problem
It's probably a grounding issue. After 40 years (plus/minus 2), electrical connections degrade. There is also a wiring harness for the lighting on the front of the vehicle that really isn't hard to change out. I had to change mine after the wire from the terminal block on the right fender became grounded on a header and fried. Note: I do not recommend trying to pull a grounded hot wire (from the battery) into two parts with your bare hands...
But check the ground wires and make sure the metal beneath them is clean and that the bolts/washers are, too. Rust makes an excellent insulator, so get rid of it. If the problem still exists after this, it's probably harness time. Check www.wiringharness.com. They have harnesses that are correctly colored and with the proper connectors. I guarantee that it will be "plug and play". There are also vendors here who have harnesses.
Member Nr. 2770
Old 08-14-2008, 08:37 AM   #3
68gmsee
Active Member
68gmsee's Avatar
I agree.. Here's a post with my problem.
I went overboard but I fought this for a week and decided I was going to make sure I had a good return to the battery from all the points (cab, engine, frame).
http://67-72chevytrucks.com/vboard/s...ight=grounding
68gmsee is offline   Reply With Quote
Old 08-27-2008, 08:26 PM   #4
SLVESSELS
I Fix My Turn Signal Problems It Was May Grill Parking Lights The Plug Had A Bad Connection I Cleaned It Out With Pb Blaster And Sand Paper Work Great Now
