Old 08-14-2008, 10:00 AM   #1
cochino12
It followed me home?
cochino12's Avatar
My first attempt at fiberglass
So I thought I would try and make some kick panels while I wait for the rest of my interior to show up. Not too bad so far I dont think, I have a fair amount of sanding to do if I am going to paint them but I might just sand them down a bit, bondo a little and them wrap them in Vinyl or carpet. I'll post some more pictures after the sanding and covering if anyone wants me to. What do you think?
Adam
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-14-2008, 10:21 AM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: My first attempt at fiberglass
Awesome, do you have any pics showing the base you started with? Also on the driverside, parking brake issue, how are you getting past that?
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 08-14-2008, 10:29 AM   #3
Cherub
Cherub's Avatar
lookin good.
Cherub is offline   Reply With Quote
Old 08-14-2008, 07:00 PM   #4
cochino12
cochino12's Avatar
I do, I'll add them tonight. As far as the parking brake goes, it clears without having to make any adjustments. I chose 5-1/4 instead of 6-1/2" speaker because of the depth to avoid any issue with the brake.
edit: I must have deleted those pictures, this is the back after being wrapped in fabric and a couple layers of glass. I used some dowels to get the angle I needed for the speaker
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-14-2008, 07:03 PM   #5
bagged74
its just $$$$$
bagged74's Avatar
looks good..
bagged74 is offline   Reply With Quote
Old 08-14-2008, 11:52 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Nice work dude. When will the production versions be available...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-15-2008, 05:40 AM   #7
mike nutt
69fatmotor
mike nutt's Avatar
the kick panels look great . i built a set for my '69 .
mike nutt is offline   Reply With Quote
Old 08-15-2008, 08:38 AM   #8
cochino12
cochino12's Avatar
Thanks for the compliments everyone. I got one side finished and painted, I think I may still try to wrap them in Vinyl but I think they ok painted too. There were a few pin holes in the bondo/fiberglass that I just couldnt get to sand out but they are only noticeable if you are right on top of them and looking for imperfections. I still need to dye the other plastics so I didnt install them all the way yet.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-15-2008, 09:02 AM   #9
seanconnery
Very trick. I was always nervous about my big goofy foot would hit it all the time if I did an install to my truck. How is the relationship between your foot and the speaker as far as distance?
G to the M to the C......fool!
RIP Jerry Reed "The Snowman"
seanconnery is offline   Reply With Quote
Old 08-15-2008, 09:11 AM   #10
tvblazer78
Low & Fast!
tvblazer78's Avatar
Looks good man!!!
tvblazer78 is offline   Reply With Quote
Old 08-15-2008, 03:01 PM   #11
copperchevy
copperchevy's Avatar
Those are going to be tricky to wrap in vinyl. Easiest way out would be to paint them. Now you need some 6x9 boxes for the cab corners.
Mexican
copperchevy is offline   Reply With Quote
