POR 15 and cab undercoat questions.
I need a couple of suggestions. I've looked around on here and I think I've decided to POR 15 my frame. I've got a line on getting in sandblasted so cleaning is not a problem. My question is this: Do I use just the black POR 15 or do I need the topcoat?
My other issue is I am wanting to clean up under the cab. How in the world do I get the underoat off? I was using a wire wheel on it some yesterday and it wasn't coming off. I think I've seen both of these issues mentioned before but after some searching (and frustration with dial up internet) I thought it might be faster to ask. Thanks for the help.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
![]() ![]() Join Date: Jul 2002
Re: POR 15 and cab undercoat questions.
One thing that helped with mine was Oven cleaner and pressure washer. Soak the stuff in oven cleaner (el ceapo stuff is great). Let is sit a while and then presuure wash it. You might need to do it severeal times, but that shoukld cut through a great deal of it . There is still going to be a lot of scraping and wire brushing, but the oven cleaner and pressure washer was a definite help.
I love POR 15, but I will caution you. If your frame is perfectly clean and smooth, it will not stick worth a darn. It likes a little surface rust. I know it doesn't make a whole lot of sense, but it is true. If you get it sand blasted and cleaned up I would then let it sit for a couple of days to get a little surface rust before painting. The straight POR tends to fade with UV light (not such a big deal on the frame) but there will be some fading. i would do the top coat if you want a shiny frame forever. If it doesn't matter to you , you don't need it. Definitely lay down some tarps to catch the drippings, and don't work in direct sunlight since it will dry quickly.
Hope this helps some! And for goodness sakes wear gloves!! It won't was off your hands and has to wear off over time.You don't want it on your Hootus!! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 08-14-2008 at 12:34 PM. |
Por-15 alone is fine as long as it sees no sun light. It has no UV protection and will fade. I used Por-15 and then their top coat on my last frame. This one I will use Por and then a cheaper chassis coat. Just don't let the Por fully harden before applying the topcoat.
67 C20/ 68 C10 stepside/inline 250--current project 71 GMC 4x4 70 Blazer project-Zombie assault vehicle 67 4x4 Burb ![]() |
I too painted my frame wit POR-15 and chasis topcoat. My suggestion would be to spray it on. It will go SO much faster and look nicer when you're done.
As for the undercoating, I read on hear that a torch and scraper work the best. I haven't done it yet, but that's what I was planning. |
i used a propane torch on as low as it could go, then a large scraper.... that took 95% of it off but for it to be perfect you will also need to wire wheel it...
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 |
auto paint suppliers have a product for removing undercoating one brand is "underoff" eastwood also carries it but youre much better off buying locally
Thanks all for the replies. Should be helpful.
I was going to do the same w/ mine is this the decote yall speak of from eastwood
http://www.yearone.com/serverfiles/f...twood&SM=1&SC=
http://i178.photobucket.com/albums/w.../james-sig.jpg 69 C-10 01 stepside 1500 86 IROC sold 76 EZGO |
Rolled on Paint Club
![]() Join Date: Jan 2006
I used oven cleaner for some and plain mineral spirits and a lot of rags and a small 1" putty knife. Just be careful with what you do with the used rags. They can combust if left in a pile or in a can or bucket with out soaking them with water.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
