08-14-2008, 12:56 PM | #1 |
Junior Member
Body mounts
Does anybody know what the difference between the 2wd and 4wd body mounts is? Has anybody bought and installed the energy suspension kit from summit in a 2wd?
Thanks Josh
1970 blazer, street/strip project 1963 ford fairlane sports coupe 50,000 original miles |
08-14-2008, 02:41 PM | #2 |
Re: Body mounts
Maybe the mounts are thicker on the 4X, but I am not sure there is a difference. I installed a set of Urethanes on my 4X, pretty straight forward, do one at a time (one side if you have to.) Good Luck
08-14-2008, 07:16 PM | #3 |
Active Member
Re: Body mounts
I got a set of repo rubber mounts from LMC, they were individually packaged by part # so if you looked at the LMC exploded diagram in their catalog, you can't go wrong knowing which mount was meant to go where. I figured that if rubber mounts lasted originally for 30+ years I'm not too worried about wear at my age...30 years from now I won't care and the price was right. Did a side at a time, there is a great post here on this site (I think in the FAQ's) that will guide you through it.
